Topic: Controlling a big stepper motor (Read 4963 times) previous topic - next topic
zeus2kx
Hi Guys,
I recently received a new big stepper motor (Model: Y07-58D1-17152) from China.
Now I am trying to collect proper devices to run this motor using Arduino.
Supplier suggested this driver.
I am not someone who has a lot of experience with stepper motor. Saying that, I prefer this driver over the other.
Which one should I purchase? Is there any cheaper alternative?
For power supply, I am thinking about this (36V 10A) ?
Earlier, I tried A4988 driver with power supply of 15V 12A (I can read this on the label, I didn't measure the current though) at maximum 2A setting. It hardly moved the motor.
I retried after around 15 min. The moment I turned on the power, A4988 got fried (saw the little fire beneath the pot).
I will be thankful for your suggestions.
Regards,
Z
zeus2kx
This or this also looks promising. What do you guys say?
Not confident which one to choose.
Robin2
#2
Feb 08, 2018, 10:43 am Last Edit: Feb 08, 2018, 10:46 am by Robin2
Either of the drivers in the Original Post should be suitable. The motor seems to require 2.2A and the drivers can provide considerably more, for a nice safety margin. Also, both will work with a 36v power supply.
If you only want to power one motor then you will not need a 10 amp power supply - but lower amperages may not give much of  saving.
...R
PS your Reply#1 came while I was composing this. I don't plan to investigate every possible option for you. - sorry, I'm lazy :)
Stepper Motor Basics
Simple Stepper Code
Two or three hours spent thinking and reading documentation solves most programming problems.
zeus2kx
Thanks Robin,
I thought motor required 3A/phase. Where did you see 2.2A?
These two drivers are relatively very cheaper (I posted them here too).
Are these fine enough as well?
Yes you are correct, the price difference betweem lower current rating (above 5A) is minor.
Also, I don't understand why supplier says this:
Quote
When the driving card is raised, it must be lower than the motor required current (otherwise, it will burn the motor) and the motor current is on the motor parameters.
Lower current rating than motor can draw would result in lower torque.
I don't get this.
Robin2
This is what I saw
Quote
Current / Phase:    2.2A
but I did not scrutinize every line of the web page.
My guess (and it is no more than that) is that the piece you quoted is intended to say "don't set the driver current higher than the motor current"
...R
zeus2kx
#5
Feb 08, 2018, 12:30 pm Last Edit: Feb 08, 2018, 02:16 pm by zeus2kx
Thanks Robin.
They have 2 different numbers. On the motor itself, it says 3A.
I will be very thankful if you could give a look into this .
I will then place order.
If the amp setting of the driver has to be lower than 3A, then I guess I go with 2.8A current setting (image attached).
Robin2
I have no idea if a TB6600 driver can work with a 3 amp motor. At the price it may be worth the risk.
...R
zeus2kx
#7
Feb 08, 2018, 03:42 pm Last Edit: Feb 08, 2018, 03:54 pm by zeus2kx
On eBay it says TB6600 supports upto 4A motor.. but can't really trust these sellers.. and this is why asking in here is always useful. I am worried about the motor, not the driver.. Unsuitable might fry the motor, what do you say?
I order it though and ST-M5045 which you saw earlier.
I will get back to this thread with some results.
Thanks to Rabin once again.
zeus2kx
...R
Hi Robin,
How are you doing?
My TB6600 driver arrived finally!
Surprisingly it can rotate the motor.
Currently DIP switch setting is for 6400 Pulse/Rev.
Test code which works: (Taken from here)
Code: [Select]
int PUL=6; //define Pulse pin
int DIR=5; //define Direction pin
int ENA=7; //define Enable Pin
  pinMode (PUL, OUTPUT);
  pinMode (DIR, OUTPUT);
  pinMode (ENA, OUTPUT);
  for (int i=0; i<6400; i++)    //Forward 5000 steps
    digitalWrite(DIR,LOW);
    digitalWrite(ENA,HIGH);
    digitalWrite(PUL,HIGH);
    delayMicroseconds(50);
    digitalWrite(PUL,LOW);
  for (int i=0; i<6400; i++)   //Backward 5000 steps
    digitalWrite(DIR,HIGH);
I also tried your Simple Stepper Code but it doesn't rotate the motor.
What is wrong?
Please suggest.
Thanks.
Robin2
What is wrong?
You need to post the exact code that you uploaded to your Arduino so I can compare it with your code that works.
My code does not write to the Enable pin - for many drivers it is not necessary. Maybe it is for the one you have.
...R
zeus2kx
#10
Feb 27, 2018, 07:13 am Last Edit: Feb 27, 2018, 08:36 am by zeus2kx
Thanks Robin,
Just to add, test code I pasted earlier only works when DIP switches are set for microstep 32.
Same code doesn't work if the microstep is different than 32.
I tried microstep 1 with:
Code: [Select]
for (int i=0; i<200; i++)
Code didn't work.
I can't seem to understand the reason.
...R
Alright, after I posted my last reply, I tried to set micro step to 1 and slightly modified your code: (snippet where I made changes)
Code: [Select]
byte directionPin = 5;
byte stepPin = 6;
int numberOfSteps = 100;
byte ledPin = 13;
int pulseWidthMicros = 200;  // microseconds
int millisbetweenSteps = 20; // milliseconds - or try 1000 for slower steps
This code moved the motor but certainly had some jitter.
Please suggest how can I smoothly rotate this motor.
Just to add, similar to my previous project, I would like to add 4 buttons (FWD, REV, EN/DIS & REST), POT for speed control and also control through serial.
Thanks a lot.
Z
Robin2
You are making it very difficult (and time wasting) when you won't post the complete program like I requested in Reply #9
Try making the motor move at a very slow speed - say 500 millis between steps
There should be no need for a long pulse width - the TB6600 datasheet says the minimum pulse requirement is 2.2µsecs so I would just use 10µsecs.
...R
zeus2kx
Like I said I didn't make any changes apart from the snippet I posted.
Anyways here is the code:
Code: [Select]
// testing a stepper motor with a Pololu A4988 driver board or equivalent
// on an Uno the onboard led will flash with each step
// this version uses delay() to manage timing
byte directionPin = 9;
byte stepPin = 8;
byte ledPin = 13;
  Serial.println("Starting StepperTest");
  digitalWrite(ledPin, LOW);
  delay(2000);
  pinMode(directionPin, OUTPUT);
  pinMode(stepPin, OUTPUT);
  pinMode(ledPin, OUTPUT);
  digitalWrite(directionPin, HIGH);
  for(int n = 0; n < numberOfSteps; n++) {
    digitalWrite(stepPin, HIGH);
    delayMicroseconds(pulseWidthMicros); // this line is probably unnecessary
    digitalWrite(stepPin, LOW);
    delay(millisbetweenSteps);
    digitalWrite(ledPin, !digitalRead(ledPin));
  delay(3000);
  digitalWrite(directionPin, LOW);
    // delayMicroseconds(pulseWidthMicros); // probably not needed
What DIP switch setting should I apply for your code?
...R
I will test these changes in the evening and update you.
Z
Robin2
#13
Feb 27, 2018, 12:20 pm Last Edit: Feb 27, 2018, 12:22 pm by Robin2
You seemed to have changed my version
Code: [Select]
int pulseWidthMicros = 20;  // microseconds
int millisbetweenSteps = 250; // milliseconds - or try 1000 for slower steps
to this
Code: [Select]
That is completely illogical. What did you hope to achieve with that? If I understand what you were thinking it makes it easier to help.
Quote
When I wrote the code I assumed single steps, but it should produce movement with any setting.
...R
zeus2kx
This is exactly what I mentioned in reply #10.
I see what you mean but these numbers came from testing the code.I was changing number to make the motor run smoothly, which I eventually saw.
Using both parameters you have in your code:
Code: [Select]
I wasn't able to move the motor.
