Topic: Soundboard With Keypad no file (Read 3929 times) previous topic - next topic
xl97
Combine WHAT code?
As far as "I" understand it.. you have only posted some keypad code..
Have you tried to work out a SEPARATE audio playback sketch/code yet?
Have you searched to see if there is a WTV Arduino library available?
Have you checked to ensure the DFRobot library wont work for your board?  (what chip set does it use?)
They seem to BOTH be audio boards that take a serial command to trigger playback.
jaredm2195
#31
Apr 11, 2018, 12:01 am Last Edit: Apr 11, 2018, 12:02 am by jaredm2195
No,yes but didn't see any,no
xl97
you should,I thought I found a few libraries and even a tutorial/post on your board specifically, you should
http://nerdclub-uk.blogspot.com/2016/06/playing-audio-with-wtv020m01-and-arduino.html
* your particular board seems to -only- with .ad4 formatted audio files.
jaredm2195
Does the WTV020-sd-16p Arduino library code work with WTV020M01?
