Topic: Sensing an object over large field (Read 310 times) previous topic - next topic
CameronSStone
What would be the best sensor or series of sensors to detect if an object is present in a large field? Specifically, shooting an arrow (5mm diameter) into a large (10ftx10ft) target. I don't need to know the location of the aarow, just yes or no if it is anywhere on the face.
123Splat
vibration sensor on the target backing or frame.
MorganS
Do you have any control over the arrow and target? For example, put a stripe of reflective tape on the arrow? Then a simple IR emitter and detector can "see" that there's a bright object on the non-IR-reflective target.
"The problem is in the code you didn't post."
CameronSStone
Both of those would definitely work, painting the aarows a florescent color would enable the use of an IR system. A colleague recommended putting a frequency emmiting device inside/on top of/attached to the aarow and then using a frequency sensor behind the target? Thank you very much for the help!
srnet
A 'frequency emitting device' is so vague as to be meaningless, was the suggestion to emit a frequency of sound, light, radio or some other emission with a frequency ?
$50SAT is now Silent (but probably still running)
http://www.50dollarsat.info/
http://www.loratracker.uk/
lastchancename
While not affecting the flight or accuracy of the arrow?
Experienced responders have a nose for laziness, (they were beginners once)... Sure, there are trolls, know-it-alls, and pretenders - but the help you'll get here is about as good as it gets - if you try to help youself!.
TomGeorge
An accelerometer on the back of the target to detect the shock of the bolt hitting the target.
That way you can detect each impact of many arrows.
Then a radio link back to the archer.
Tom.... :)
Everything runs on smoke, let the smoke out, it stops running....
