Topic: Uploading code thru ISP Issue (Read 496 times) previous topic - next topic
Arrghsenal
Hello everyone,
My project involves making a fish robot squiggle its tail, controlled by the Nano inside the fish. As I don't want to open the robot up everytime I upload code to take the Nano outside, I used ISP as a way to do it. The robot's motor is powered by a battery, so I unplugged the Uno after every upload.
I'm having an issue that I followed the proper method for ISP code upload as laid out by the Arduino website. In the first time I upload the code and removed the Uno connection from the Nano so the fish can move underwater, everything works out fine. I updated my code and uploaded it the same way, but the fish never moves again.
I have tried putting a capacitor between reset and ground on the Uno, and connecting a 30K resistor between pin 10 (reset) on the Uno and 3V3 pin, but none of these have been successful. This problem is also reproducible, since every day I have had trouble with this issue.
I'll provide more details if anyone needs it. Please help me with this issue. Thanks a lot.
spycatcher2k
Quote
Then it's an issue with your code!
Mrs Drew
http://www.uk-pcb.co.uk - UK PCB Fab Company
I will design & code for you, but I will also charge you (PM me)
If you don't like my answers, realize : I'm not being cheeky, I'm Just trying to prompt you to use your own brain/google etc.
wvmarle
Try putting back your known-good code.
Or try re-uploading it, maybe something went wrong there.
Quality of answers is related to the quality of questions. Good questions will get good answers. Useless answers are a sign of a poor question.
Arrghsenal
I mean that even if I keep the same code, the same issue still happens again. I unplugged the Uno to switch to using batteries as a power supply, and the issue keeps popping back up
Arrghsenal
I noticed some other things. When I plug the UNO which is also my ISP Programmer and have it connected to the Nano, the robot moves just fine. However, when I removed the UNO and switch to battery as a power source, nothing happens. Please help !!! Thanks
wvmarle
That quite strongly points to a power issue. And that can be anything. Dead battery, loose wire, too low voltage...
Arrghsenal
i have another issue with ISP programming. There are several times that my laptop just suddenly shuts down after ISP uploading. Has anyone ever encountered this before and please help!!! Thx
jremington
We won't be able to help until you post a complete wiring diagram (hand drawn, not Fritzing).
