Topic: Automatic beer-opener, using a servo-motor solenoid and then the servo again (Read 656 times) previous topic - next topic
Stinoenthom
Hi guys,
I am really bad at programming i just put some code from the internet together i hoped that someone could help me with my project for school.
What i am trying to accomplish is that the beer pushes down a button, the  button activates the servo to turn 180 degrees so the opener is right on top of the beer, when the servo has turned the solenoid pushes the opener up with enough power to open it up. After the solenoid pushed it up the servo turns back 180 degrees and then the cycle is done.
I really hope someone is able to help met with this.
I added the program i made (it probably is just a lot of bullshit) and a sketchup of our 'robot'.
thanks in advance,
Thom
slipstick
So a "beer-opener"? What is the beer in, a bottle, a can, a barrel, something else?
I can't see any sketchup which might have given a hint.
Steve
Stinoenthom
https://3dwarehouse.sketchup.com/model/22dc3266-f01b-4dcd-918e-414c0d802aec/Bierbot
the .skp file was to big to upload here is the link.
(it is in a bottel by the way)
TomGeorge
Welcome to the forum.
http://forum.arduino.cc/index.php/topic,148850.0.html
You need to post you image as jpg, png or pdf.
Not everybody has access to the app that made the skp file.
Tom... :)
Everything runs on smoke, let the smoke out, it stops running....
Stinoenthom
Here it iss. I changed the robot a little though but that doesn't do anything to the way it should be programmed.
TomGeorge
OPs Code
Code: [Select]
#include <Servo.h>
Servo myservo;  // create servo object to control a servo
// twelve servo objects can be created on most boards
int pos = 0;    // variable to store the servo position
int solenoidPin = 4;    //This is the output pin on the Arduino we are using
int pushButton = 2;
int degree
 pinMode(solenoidPin, OUTPUT);           //Sets the pin as an output
 myservo.attach(9);  // attaches the servo on pin 9 to the servo object
 Serial.begin (9600);
 pinMode (pushButton, INPUT);
 int buttonState = digitalRead (pushButton);
 Serial.println(buttonState);
 delay(1);
if (buttonState , HIGH){
 for (pos = 0; pos <= 180; pos += 1){//gaat van 0 naar 180 graden
  myservo.write (pos);
  delay (15);
  if (pos >179){
  analogWrite
if (pos = 180){
 digitalWrite(solenoidPin, HIGH);    //Switch Solenoid ON
  delay(1000);                      //Wait 1 Second
  digitalWrite(solenoidPin, LOW);     //Switch Solenoid OFF
  if (pos = 180; pos >= 0; pos -= 1) { // goes from 180 degrees to 0 degrees
    myservo.write(pos);              // tell servo to go to position in variable 'pos'
    delay(15);                       // waits 15ms for the servo to reach the position }
Try to avoid  doing   }}}
put them to separate lines and do a Auto-Format in the IDE, press   CTRL-T.
Your code formated;
Code: [Select]
#include <Servo.h>
int pushButton = 2;
int degree
  delay(1);
  if (buttonState , HIGH) {
    for (pos = 0; pos <= 180; pos += 1) { //gaat van 0 naar 180 graden
      delay (15);
      if (pos > 179) {
        analogWrite
    if (pos = 180) {
OPs diagram
Tom.... :)
slipstick
What is this bit of code supposed to do?
Code: [Select]
      if (pos > 179) {
        analogWrite
Steve
Stinoenthom
it is supposed to stop the servo from turning back 180 degrees, when i uploaded my code it. turned 180 and back i was trying to stop it from doing that insteantly but i forgot to finish the code i guess.
TomGeorge
How are you powering your servo?
What model is the servo?
What is the solenoid and how are you controlling it?
Thanks.. Tom.. :)
Stinoenthom
hi i put the sketch of my cicuit as an attachment and also specifications of the solenoid and the servo.
"'the sketch is to big how do i upload it?
wvmarle
OP's images:
Do you have a working prototype already? (maybe manually operated so at least you have the size and motion correct)
Quality of answers is related to the quality of questions. Good questions will get good answers. Useless answers are a sign of a poor question.
Stinoenthom
heey guys thanks for the imput i finished it myself and it works!!
lastchancename
(Short close-up video please)
While a worthy goal, i'd be suspicious of using a solenoid to 'pop the bottle top'.
A solenoid imparts a very short impulse of mechanical energy, which is just as likely to take the neck off the bottle??
If I was building this, an arrangement of servos is fine to position the opener and bottle - but, i'd use a stronger geared-down servo/motor to apply the progressive force needed to lift the cap.
Experienced responders have a nose for laziness, (they were beginners once)... Sure, there are trolls, know-it-alls, and pretenders - but the help you'll get here is about as good as it gets - if you try to help youself!.
