Topic: Arduino Bluetooth Module HC-05 Unstable Serial Inuput (Read 319 times) previous topic - next topic
Gp25
Hy there......!
I am currently working on a rover project which is controlled by a HC-05 Bluetooth Module
The code im using works great
But the Bluetooth Module is not sending serial input (TX) data to Arduino property
A moment it works fine
Few moments later , that is after reconnecting its not sending data
I'm using an Arduino Uno and im stuck with this for like a month
 Can anyone please help me
And thanks in advance
Nick_Pyner
Probably not
Your code, which "works great" quite likely doesn't, but nobody will ever know because it is apparently a secret, and much the same can be said for the rest of your project.
Gp25
Well this is the code im using
// Starting of Program
int m1a = 10;
int m1b = 11;
int m2a = 12;
int m2b = 13;
char val;
pinMode(m1a, OUTPUT);  // Digital pin 10 set as output Pin
pinMode(m1b, OUTPUT);  // Digital pin 11 set as output Pin
pinMode(m2a, OUTPUT);  // Digital pin 12 set as output Pin
pinMode(m2b, OUTPUT);  // Digital pin 13 set as output Pin
  while (Serial.available() > 0)
  val = Serial.read();
  Serial.println(val);
  if( val == 'F') // Forward
      digitalWrite(m1a, HIGH);
      digitalWrite(m1b, LOW);
      digitalWrite(m2a, HIGH);
      digitalWrite(m2b, LOW);
  else if(val == 'B') // Backward
      digitalWrite(m1a, LOW);
      digitalWrite(m1b, HIGH);
      digitalWrite(m2a, LOW);
      digitalWrite(m2b, HIGH);
    else if(val == 'L') //Left
    else if(val == 'R') //Right
  else if(val == 'S') //Stop
  else if(val == 'I') //Forward Right
  else if(val == 'J') //Backward Right
   else if(val == 'G') //Forward Left
  else if(val == 'H') //Backward Left
// End of program
TomGeorge
Welcome to the forum.
http://forum.arduino.cc/index.php/topic,148850.0.html then look down to item #7 about how to post your code.
It will be formatted in a scrolling window that makes it easier to read.
Tom... :)
Everything runs on smoke, let the smoke out, it stops running....
Robin2
Have a look at the examples in Serial Input Basics - simple reliable ways to receive data.
...R
Two or three hours spent thinking and reading documentation solves most programming problems.
