Topic: Serial.readBytesUntil(); (Read 8056 times) previous topic - next topic
Shinyhero
I would like to kinow whar is the code to read the serial until the enter key is pressed
here is my code:
while(!Serial.available()); byte choix = Serial.readBytesUntil('\n');
but i've got an error
Alain46
Check Arduino documentation readBytesUntil(). This function returns an array not a byte
Un programme qui se compile sans erreur n'est pas forcément un programme qui fonctionne.
Shinyhero
what should i had int the command
Serial.readBytesUntil(character, buffer, length)
hbachetti
You should read the documentation :
https://www.arduino.cc/en/Reference/StreamReadBytesUntil
 char buffer[16];
 int size = Serial.readBytesUntil('\n', buffer, 16);
 for (int i = 0 ; i < size ; i++) {
   Serial.println(buffer[i], HEX);
Hope it helps ...
Linux is like a wigwam: no Windows, no Gates, and an Apache inside ...
Robin2
Have a look at the examples in Serial Input Basics - simple reliable ways to receive data.
...R
Two or three hours spent thinking and reading documentation solves most programming problems.
