Topic: 16*128 dot matrix display connection (Read 420 times) previous topic - next topic
gourish
hi
i tried a code of 16*32 dot matrix on 16* 128 dot matrix display.
Code: [Select]
#include "myMATRIX.h"
#define RowA_Pin 2
#define RowB_Pin 3
#define RowC_Pin 4
#define RowD_Pin 5
#define OE_Pin 6
#define Red_Pin 7
#define Green_Pin 8
#define CLK_Pin 9
#define STB_Pin 10
void setup ()
     myMatrix.Init(Red_Pin,Green_Pin,CLK_Pin,RowA_Pin,RowB_Pin,RowC_Pin,RowD_Pin,OE_Pin,STB_Pin);
 myMatrix.clearScreen();
 myMatrix.printString(5,8,yellow,black,"Demo");
it gives me output on the display but it is repeating the displayed text after some pixel again.
is there any other pin configuration and library for 16*128 dot matrix display?
thank you
Jakub12
#1
Feb 12, 2018, 01:44 pm Last Edit: Feb 12, 2018, 01:50 pm by Jakub12
Use md Parola and md_max  library. Over there you can decide how many modules are in your display like :
#define MAX_DEVICES 12
Jakub12
You can find this libraries here:
And later you can find some examples , in your case that will be zones , because you want to display something in certain space of display:
Good luck !
marco_c
Is your matrix controlled by the MAX7219 IC? You provide no details of the type of matrix you are using.
Quote
With the 7219IC this means that there are more matrices than the software thinks there are. When you update the display, the serial data communications pushed the 'current' data off the end of the 'known' modules into the others, which will show the old display as was previously on the 'known' modules before they were updated.
You need to find somewhere in the library that has the number of modules and change that to be those for your matrix.
If they are not controlled by the MAX7219, then this explanation may not be correct for your matrix.
Arduino Libraries https://github.com/MajicDesigns?tab=Repositories
Parola for Arduino https://github.com/MajicDesigns/Parola
Arduino++ blog https://arduinoplusplus.wordpress.com
gourish
Quote
Thank you..
Quote
40-inch 101cm ios And Android Wifi wireless remote Programmable Advertising LED Display Board, Bright Red led sign for Busines
i dont know whether it uses max7219 ic..
gourish
Quote
in this library there is nothing mentioned about the connection for r1,g1 and r2,g2
