Topic: temperatura ballonzolante TMP36 (Read 1 time) previous topic - next topic
vince59
Feb 12, 2018, 11:36 pm Last Edit: Feb 12, 2018, 11:37 pm by vince59
...bsera a tutti. Un semplicissmo codice per leggere la temperatura...ma ballonzola molto.
Perchè?
Suggerimenti per renderla più stabile?
Grazie
Code: [Select]
The circuit:
* LCD RS pin to digital pin 12
* LCD Enable pin to digital pin 11
* LCD D4 pin to digital pin 5
* LCD D5 pin to digital pin 4
* LCD D6 pin to digital pin 3
* LCD D7 pin to digital pin 2
* LCD R/W pin to ground
* 10K resistor:
* ends to +5V and ground
* wiper to LCD VO pin (pin 3)
// include the library code:
#include <LiquidCrystal.h>
// initialize the library with the numbers of the interface pins
LiquidCrystal lcd(12, 11, 5, 4, 3, 2);
 lcd.begin(16, 2);
  int TEMP = analogRead(A0);
  // PRIMO METODO LETTURA
  float volt = (TEMP/1020.0) * 4.9;
  float tempC = (volt - 0.5) * 100;
  //SECONDO METODO LETTURA
  float tempC=((TEMP*0.00488)-0.5)/0.01;
  lcd.setCursor(0,0);
  lcd.print("Temperatura");
  lcd.setCursor(0,1);
  lcd.print(tempC);
  Serial.println(tempC);
  lcd.print(" C");
vince59
..ho trovato un altro codice..però però..vorrei ottimizzarlo anche magari con modifiche hardware
Code: [Select]
int temperaturaMassima = 27;
const int NRLETTURE = 12; // numero letture
const int SensorPin = A0; //variabile lettura sensore
float valori[NRLETTURE]; //array con i valori
int T_campionamento = 80; // tempo campionamento
float sommaGradi; //variabile somma
float mediaGradi; //variabile media
#include <LiquidCrystal.h> // includo la libreria del display lcd
LiquidCrystal lcd(12, 11, 5, 4, 3, 2); //pin display LCD
  // set up the LCD's number of columns and rows:
  lcd.begin(16, 2);
  Serial.begin(9600); //inizializzo la seriale
  lcd.print("--");
  lcd.setCursor(0,2);
  lcd.print("--");
  delay(3000);
  pinMode(13,OUTPUT);
  digitalWrite(13,LOW);
  for ( int i = 0; i<=NRLETTURE;i++)
    int sensorVal = analogRead(SensorPin);
  float voltage = (sensorVal /1024.0) * 5.0;
  float temperature = (voltage - .5) * 100;
    valori[i] = temperature;
    delay(T_campionamento);
   sommaGradi = 0; // devi essere sicuro che il primo valore sia zero, altrimenti poi sballa tutto
  for(int i=0; i<NRLETTURE; i++) { //ciclo che somma i valori dell'array
    sommaGradi = sommaGradi + valori[i];
     mediaGradi = sommaGradi / NRLETTURE; //divido la somma dei valori per il loro numero (media)
      lcd.clear(); //pulisco lo schermo
  Serial.print ("Gradi: "); //scrivo sul display la parola "gradi"
  Serial.println(mediaGradi); //scrivo la temperatura sulla seriale
  lcd.print("Temperatura:"); //scrivo sul display la parola "temperatura"
  lcd.setCursor(0,2); //sposto il cursore sulla seconda linea
  lcd.print(mediaGradi); //scrivo la temperatura
  lcd.print(" Gradi"); // scrivo sul display la parola "gradi"
if (mediaGradi >temperaturaMassima)
  digitalWrite(13,HIGH);
  Serial.println("Temperatura raggiunta!!!!");
  else {
uwefed
Dipende tutto quanto costante é la tensione di alimentazione.
Ciao Uwe
vince59
Ciao Uwe
Bgiorno Uwe, ora sto alimentando con i 5VCC di Arduino...quasi quasi provo ad inserire il "ref".
Al momento è un monmtaggio sperimentale su millefori però devo utilizzarla come sonda per alcuni rilievi qundi salderò il TMP ad una cavetto di una 40 di cm.
...balla troppo più di un grado
gpb01
#4
Feb 13, 2018, 08:36 am Last Edit: Feb 13, 2018, 08:40 am by gpb01
Puoi anche provare semplicemente ad aggiungere un condensatore da 220μF in parallelo all'alimentazione ed ha fare più acquisizioni (es. 10 distanziate di 100 msec l'una dall'altra) calcolandone la media.
Il problema NON è nella stabilità dell'alimentazione verso il TMP36, quanto della MCU, che utilizza i 5V come Vref del ADC. Se questi non sono stabili, ecco che le misure oscillano.
Oppure, se il limite superiore di circa 60° ti basta (dato che lo 0° è a 500mV, ti rimane solo il range da 500mV a 1.1V, ovvero circa 600mV di scala verso i valori positivi di temperatura, pari appunto a circa 60°), potresti anche usare il riferimento interno da 1.1V che è piuttosto stabile (anche se non sempre esattamente a 1.1V, il che ti richiede una piccola correzione per avere la temperatura reale, correzione che comunque ... è quasi sempre necessaria per correggere piccole differenze di misura).
Guglielmo
Search is Your friend ... or I am Your enemy !
vince59
#5
Feb 13, 2018, 08:58 am Last Edit: Feb 13, 2018, 09:09 am by vince59
Bgiorno Guglielmo...smanetto un pò e vi aggiorno. Grazie ad entrambi per i chiarimenti.
update: con l'elettrolitico è molto più stabile. IN effetti avevo letto della stabilità e sarei dovuto arrivarci da solo.
MI metto una sufficenza...scarsa. Che ne dici Gugliemo?
gpb01
#6
Feb 13, 2018, 09:58 am Last Edit: Feb 13, 2018, 09:58 am by gpb01
Ahahahahahahah ... ok ... :D
... se in più fai la media di un 10/15 misure, lo rendi ancora più stabile ... ;)
Guglielmo
vince59
Gugliemo...
perchè la IDE 1.8.5. non mi riconosce la libreria che invece è ricnosciuta dalla IDE 1.0.6?
gpb01
Libreria? Che libreria ? da dove l'hai scaricata/installata ?
Guglielmo
P.S.: ... e comunque, dalla 1.0.6 alla 1.8.5 ... moltissime cose sono cambiate e tante cose vanno corrette.
vince59
si Guglielmo me ne sono accorto. Utilizzo arduino su un muletto sony xp/sp3 ed ogni tanto mi tocca litigare con le IDE. Utilizzo la vecchia 1.0.6 e vado tranquillo...in pratica la 1.8.5 trovava qualcosa da qualche parte che nongli andava giù.
Guglielmo ora sono soddisfatto della stabilità della sonda. Ora devo provare a collegarne due per rilevare la T in entrata ed uscita. Immagino si sufficente solo duplicare la lettura/conversione su un secondo pin analogico....giusto?
gpb01
#10
Feb 13, 2018, 03:11 pm Last Edit: Feb 13, 2018, 03:12 pm by gpb01
SI, ma ricorda, per precauzione, al cambio di pin analogico, di scartare la prima lettura. Se fai un po' di ricerche qui sul forum trovi anche qualche discussione con la spiegazione in dettaglio del perché ;)
Guglielmo
vince59
...il  codice è pronto devo trovare nei cassetti un altro tmp36.
DOMANDA: volendo correggere il rilevamento del tmp36 (leggo un pò meno se comparato ad altri strumenti) dove mi conviene intervenire nella formula?
gpb01
... direttamente sul risultato finale. Prendi un termometro di cui sei certo, verifica la differenza ed applicala al valore calcolato (... del resto, il TMP36, ha una "accuratezza" di +/- 2° C, quindi, normalmente, occorre applicare una correzione).
Guglielmo
vince59
#13
Feb 16, 2018, 11:50 am Last Edit: Feb 16, 2018, 08:28 pm by vince59
Bjour...questo è il semplice codice per un termometro a due sonde (potrebbe essere semplicemente adattato per farne un termostato). Ancora non ho trovato nei cassetti del garage il secondo TMP ma  il codice sembra girare bene.
Ciò premesso grazie a tutti voi odio il delay (del campionamento) :)  che quindi vorrei sostituire con un millis (di cuiormai sono un esperto  :smiley-confuse: )
Ho provato con diversi approcci a posizionare il millis nel codice (prima del loop, prima di ogni cilco di misurazione, allafine del loop) ma non sono riuscito a farlo girare in modo appropriato. Dove devo inserirlo?
Una cosa che non mi spego è perchè inviando il segnale del sensore ad entrambi i pin (A0 ed A1) mi vengono indicate due temperature diverse di circa due gradi
Code: [Select]
const int NRLETTURE = 10;    // numero letture
const int NRLETTURE2 = 10;
const int SensorPin2 = A1;   // seconda variabileb sensore due
float valori2[NRLETTURE2];
int T_campionamento = 50;    // tempo campionamento
int T_campionamento2 = 50;
float sommaGradi2;
float mediaGradi2;
#include <LiquidCrystal.h>             // include la libreria del display lcd
//long previousMillis = 0;
//long interval = 50;
  lcd.begin(16, 2);        // set up the LCD's number of columns and rows:
  lcd.print("Created by: ");
  lcd.setCursor(0,2);
  lcd.print("ppregeo");
  //delay(3000);
    float voltage = (sensorVal /1024.0) * 5.0; //dividendo per 1024.0 da una lettura inferiore.
    //float temperature = ((sensorVal * 0.00488) - 0.5) / 0.01;
    /* int sensorVal2 = analogRead(SensorPin2);
     float voltage2 = (sensorVal2 /1024.0) * 5.0;
     float temperature2 = (voltage2 - .5) * 100;
     valori[i] = temperature2;
     delay(T_campionamento); */
  sommaGradi = 0;                        // il primo valore deve essere sia zero, altrimenti poi sballa tutto
  for( int i = 0; i<=NRLETTURE; i++)     //ciclo che somma i valori dell'array
    sommaGradi = sommaGradi + valori[i];   //sommaGradi2 = sommaGradi2 + valori[i];
  mediaGradi = sommaGradi / NRLETTURE;   //media valori
  for ( int i = 0; i<=NRLETTURE2;i++)
    delay(T_campionamento2);
  sommaGradi2 = 0;
  for( int i = 0; i<=NRLETTURE2; i++)        //ciclo che somma i valori dell'array
  mediaGradi2 = sommaGradi2 / NRLETTURE2; //divido la somma dei valori per il loro numero (media)
  //--------------- prova delay ----------------
  //    unsigned long currentMillis = millis();
  //    if (currentMillis - previousMillis > interval) {
  //    previousMillis = currentMillis;
  //delay(T_campionamento);
  lcd.clear();                              //pulire lo schermo
  Serial.print ("Temp IN:    ");            //scrive sul display la parola "gradi"
  Serial.println (mediaGradi);
  Serial.print ("Temp OUT:   ");
  Serial.println (mediaGradi2);
  Serial.print ("diff:       ");
  Serial.println (mediaGradi-mediaGradi2);
  Serial.println ("---------------------------------------------");
  //lcd.setCursor(1,1);
  lcd.print("In ");
  //lcd.setCursor(4,1);                //sposto il cursore sulla seconda linea
  lcd.print(" d ");
  lcd.print(mediaGradi-mediaGradi2);
  lcd.setCursor(0,2);
  lcd.print("Out ");
  lcd.print(mediaGradi2);
vince59
...ora è perfetto. Sono due LM35 dato che non avevo due TMP35.
Ecco il codice se dovesse servire a qualcuno...anche come termostato
Code: [Select]
float sommaGradi2;
float mediaGradi2;
  lcd.setCursor(0,2);
  //delay(3000);
    //float voltage = (sensorVal /1024.0) * 5.0; //dividendo per 1024.0 da una lettura inferiore.
    //float temperature = (voltage - .5) * 100;
    float temperature = (sensorVal * 4.88)/10;
    //float voltage2 = (sensorVal2 /1024.0) * 5.0;
    //float temperature2 = (voltage2 - .5) * 100;
    float temperature2 = (sensorVal2 * 4.88)/10;
    valori2[i] = temperature2;
  sommaGradi2 = 0;
  lcd.print("In ");
  lcd.print(" d ");
  lcd.setCursor(0,2);
  lcd.print("Out ");
