Topic: how can i use input_pullup  (Read 672 times) previous topic - next topic
ap16
I want to setup 2 switches and 3 leds. When switch 1 is pressed an led(red) comes on and when switch 2 is pressed another led(green) comes on. Then when switch 1 and switch 2 are both pressed all the leds come on(white).
larryd
Show us what you have done.
Show us a good schematic of your circuit.
Show us a good image of your wiring.
Always show us your 'current' compete sketch.
Use CTRL T to format the sketch.
Please use code tags.
Use the </> icon in the posting menu.
[code] Paste sketch here. [/code]
No technical PMs.
If you are asked a question, please respond with an answer.
If you are asked for more information, please supply it.
If you need clarification, ask for help.
CrossRoads
Here are basics, see if you can work it out:
pinMode (pin2, INPUT_PULLUP);
pinMode (pin3, INPUT_PULLUP);
pin2state = digitalRead (pin2);
pin3state = digitalRead(pin3);
if (pin2state == LOW && pin3state == LOW){
// do one thing
if (pin2state == HIGH && pin3state == LOW){
// do one thing
if (pin2state == LOW && pin3state == HIGH){
// do one thing
if (pin2state == HIGH && pin3state == HIGH){
// do one thing
ap16
here is my circuit https://imgur.com/a/Zzq7r
larryd
Show us your current sketch also.
No technical PMs.
larryd
#5
Feb 13, 2018, 04:51 pm Last Edit: Feb 13, 2018, 04:54 pm by larryd
If you push switch #1 then let go, does the red LED follow the switch?
Do red and green come on if both switches are pushed?
What is this to be used for?
No technical PMs.
ap16
// do one thing
// do one thing
// do one thing
// do one thing
thanks for that but i'm not getting a light I used digitalWrite
larryd
Use CTRL T to format the sketch. Please use code tags.
No technical PMs.
Grumpy_Mike
#8
Feb 14, 2018, 08:52 am Last Edit: Feb 14, 2018, 08:53 am by Grumpy_Mike
You did replace the lines
// do one thing
With a line of code that actually did something like turn your light on?
You need to write a LOW to turn on your light.
