Topic: SOLVED (Thanks) "if" and "els" with distance sensor and LCD display (Read 636 times) previous topic - next topic
MichDragstar
Dear friends, What I would like to do: Getting distance (ultra sonic sensor) in cm on LCD (that part is OK)
I have somewhere and error in the last part (I think) of the code with "if" and "else" and I am really stuck with it. I just don't see it. I would like to read: When the distance from sensor to waterlevel is >40cm, on the LCD I would like to read "LEV LOW" (that part is OK.)
When the distance is <40 and  >20 , it must be LEV MED (level medium). (that part is OK too)
And now the trouble part: When the distance is <20 I would like to read "LEV HIGH"
I only get the messages LOW and MED, never HIGH. I tried and I searched without results. So all my hope is on you guys. Thanks a lot for your help. It means a lot to me. Kind regards, Michel.
Code: [Select]
#include <LiquidCrystal.h>//Load Liquid Crystal Library
LiquidCrystal LCD(12, 11, 5, 4, 3, 2);  //Create Liquid Crystal Object called LCD
int trigPin=9; //Sensor Trip pin connected to Arduino pin 9
int echoPin=7;  //Sensor Echo pin connected to Arduino pin 7
int myCounter=0;  //declare your variable myCounter and set to 0
int servoControlPin=6; //Servo control line is connected to pin 6
float pingTime;  //time for ping to travel from the sensor to the target and return
float targetDistance; //Distance to Target in Centimeters
float speedOfSound=776.5; //Speed of sound in miles per hour
pinMode(trigPin, OUTPUT);
pinMode(echoPin, INPUT);
LCD.begin(16,2); //Tell Arduino to start your 16x2 LCD
LCD.setCursor(0,0);  //Set LCD cursor to upper left corner, column 0, row 0
LCD.print("Distance:");  //Print Message on First Row
  digitalWrite(trigPin, LOW); //Set trigger pin low
  delayMicroseconds(2000); //Let signal settle
  digitalWrite(trigPin, HIGH); //Set trigPin high
  delayMicroseconds(15); //Delay in high state
  digitalWrite(trigPin, LOW); //ping has now been sent
  delayMicroseconds(10); //Delay in high state
  pingTime = pulseIn(echoPin, HIGH);  //pingTime in microceconds
  pingTime=pingTime/1000000; //convert pingTime to seconds by dividing by 1000000 (microseconds in a second)
  pingTime=pingTime/3600; //convert pingtime to hours by dividing by 3600 (seconds in an hour)
  targetDistance= speedOfSound * pingTime;  //This will be in miles, since we declared the speed of sound as kilometers per hour; although we're going to convert it back to centimeters
  targetDistance=targetDistance/2; //Remember ping travels to the target and back from the target, so you must divide by 2 for actual target distance.
  targetDistance= targetDistance*160934,4;    //Convert miles to centimeters by multipling by 160934,4
  LCD.setCursor(0,1);  //Set the cursor to the first column of the second row
  LCD.print("                "); //Print blanks to clear the row
  LCD.setCursor(0,1);   //Set Cursor again to the first column of the second row
  LCD.print(targetDistance); //Print measured distance
  LCD.print(" cm ");  //Print your units
 if (targetDistance > 40) {
      LCD.print("LEV LOW ");
else if (targetDistance < 40 || targetDistance > 20) {
      LCD.print("LEV MED ");
else (targetDistance < 20); {
  LCD.print ("LEV HI ");
  delay(1250); //Pause to let things settle
CtrlAltElite
Code: [Select]
else (targetDistance < 20); {  <<<<---- OH DEAR, NO
Has there been an outbreak of the stupid virus, and I didn't get the memo?
PaulS
Code: [Select]
pulseIn() does not return a float.
Code: [Select]
The decimal point in C++ is ., not ,. The comma operator means something completely different.
Code: [Select]
What is this supposed to be doing? That's not an else if statement, since the if is missing.
The (targetDistance < 20) part is a valid statement, but it is meaningless. The value might be less than 20, but so what?
MichDragstar
Sorry, I did something wrong while posting. Please find the story, see my post 7.25pm
evanmars
#4
Feb 15, 2018, 08:39 pm Last Edit: Feb 15, 2018, 08:41 pm by evanmars
Code: [Select]
Maybe should be
Code: [Select]
else if (targetDistance < 40 && targetDistance > 20) {
Code: [Select]
could be just
Code: [Select]
else {   // no ;
MichDragstar
Code: [Select]
Code: [Select]
Code: [Select]
Code: [Select]
Code: [Select]
Code: [Select]
when distance less than 20cm I would like to read "LEV HIGH" on display.
Code: [Select]
Code: [Select]
Code: [Select]
Code: [Select]
Code: [Select]
Code: [Select]
I was hoping to read  "LEV HI" see: else (targetDistance < 20); {
CtrlAltElite
 else (targetDistance < 20);<- NO SEMICOLON HERE, EVER!
MichDragstar
I tried a lot of things, with and without dots etc....... Thank you for helping me. Can you please rewrite the last part of the code as it should be. Are there other things in the entire code to change?
evanmars
MichDragstar
Code: [Select]
Maybe should be
Code: [Select]
Code: [Select]
could be just
Code: [Select]
else {   // no ;
Yes, thank you. I have to check it out. Thanks a lot.
MichDragstar
When I remove ; I get an error Arduino: 1.8.2 (Windows 7), Board:"Arduino/Genuino Uno"
C:\Users\Michel\Documents\Arduino\sketch_feb14a\sketch_feb14a.ino: In function 'void loop()':
sketch_feb14a:53: error: expected ';' before '{' token
 else (targetDistance < 20) {
exit status 1
CtrlAltElite
Did you see the post that tells you to post all your code?
evanmars
exit status 1
I didn't, compiled fine for me with just
Code: [Select]
else {
MichDragstar
Code: [Select]
Maybe should be
Code: [Select]
Code: [Select]
could be just
Code: [Select]
else {   // no ;
Thanks a lot, problem solved, you are right || must be && . Thanks friend, you made my day!!
MichDragstar
The complete code is above, but the problem is solved now. Thank you all for helping me so fast. Wish I could do something for you guys, but Arduino is still a bit new for me, sorry. Kind regards, Michel
