Topic: Continuous Servo, moving slowly (Read 4128 times) previous topic - next topic
RoboElite
I have two Parallax servo motors as wheels to move a robot. I was researching about the motors and how to slow them down. I understand you cant really control the speed of the servo but I did manage to find a sketch. The sketch uses ONE continuous servo to move slowly, counterclockwise or clockwise. I was very intrigued by this because it just might work for my design. However, I am using two continuous servos. I've tried to manipulate the sketch to work for two servos. Although I managed to make it work, I don't know how manipulate the code so that one servo goes clockwise and the other counterclockwise. Which is why I am seeking help. It will be very helpful if someone can review the code and help me change it so that one servo goes clockwise and the other goes counterclockwise, slowly and at the same time.
Code: [Select]
int RW     =  7;    // right wheel
int LW     =  8;            // left wheel
int minPulse     =  1170;  // maximum servo speed clockwise
int maxPulse     =  1770; // maximum servo speed anticlockwise
int turnRate     =  75;  // servo turn rate increment (larger value, faster rate)
int refreshTime  =  20;   // time (ms) between pulses (50Hz)
/** The Arduino will calculate these values for you **/
int centerServo;         // center servo position
int pulseWidth;          // servo pulse width
int moveServo;           // raw user input
long lastPulse   = 0;    // recorded time (ms) of the last pulse
 pinMode(RW, OUTPUT);  // Set servo pin as an output pin
 pinMode(LW, OUTPUT);
 centerServo = maxPulse - ((maxPulse - minPulse)/2);
 pulseWidth = centerServo;   // Give the servo a stop command
 Serial.println("Arduino Serial Continuous Rotation Servo Control");
 Serial.println("          by Orfeus for GRobot.gr");
 Serial.println("   Press < or > to move, spacebar to center");
 // wait for serial input
 if (Serial.available() > 0) {
   // read the incoming byte:
   moveServo = Serial.read();
   // ASCII '<' is 44, ASCII '>' is 46 (comma and period, really)
   if (moveServo == 44) {
         pulseWidth = pulseWidth + turnRate;
   if (moveServo == 46) {
         pulseWidth = pulseWidth - turnRate;
   if (moveServo == 32) {
   // stop servo pulse at min and max
  if (pulseWidth > maxPulse) { pulseWidth = maxPulse; }
   if (pulseWidth < minPulse) { pulseWidth = minPulse; }
    //print pulseWidth back to the Serial Monitor (comment to undebug)
    Serial.print("Pulse Width: ");
    Serial.print(pulseWidth);
    Serial.println("us");
 // pulse the servo every 20 ms (refreshTime) with current pulseWidth
 // this will hold the servo's rotation and speed till we told it to do something else.
 if (millis() - lastPulse >= refreshTime) {
   digitalWrite(RW, HIGH);   // start the pulse
   digitalWrite(LW, HIGH);   // start the pulse
   delayMicroseconds(pulseWidth);  // pulse width
   digitalWrite(RW, LOW);    // stop the pulse
   digitalWrite(LW, LOW);    // stop the pulse
   lastPulse = millis();           // save the time of the last pulse
zoomkat
Below is some servo code I use to test two continous rotation servos using the serial monitor. With 1500us as the mid point the servo direction/speed is varied using ~+-100us or less from the 1500us.
Code: [Select]
// zoomkat 11-22-10 serial servo (2) test
// for writeMicroseconds, use a value like 1500
// for IDE 0019 and later
// Powering a servo from the arduino usually DOES NOT WORK.
// two servo setup with two servo commands
// send eight character string like 15001500 or 14501550
#include <Servo.h>
String readString, servo1, servo2;
Servo myservo1;  // create servo object to control a servo
Servo myservo2;
  myservo1.attach(6);  //the pin for the servo control
  myservo2.attach(7);
  Serial.println("servo-test-21"); // so I can keep track of what is loaded
  while (Serial.available()) {
    delay(1);
    if (Serial.available() >0) {
      char c = Serial.read();  //gets one byte from serial buffer
      readString += c; //makes the string readString
  if (readString.length() >0) {
      Serial.println(readString); //see what was received
      // expect a string like 07002100 containing the two servo positions
      servo1 = readString.substring(0, 4); //get the first four characters
      servo2 = readString.substring(4, 8); //get the next four characters
      Serial.println(servo1);  //print to serial monitor to see results
      Serial.println(servo2);
      int n1; //declare as number
      int n2;
      char carray1[6]; //magic needed to convert string to a number
      servo1.toCharArray(carray1, sizeof(carray1));
      n1 = atoi(carray1);
      char carray2[6];
      servo2.toCharArray(carray2, sizeof(carray2));
      n2 = atoi(carray2);
      myservo1.writeMicroseconds(n1); //set servo position
      myservo2.writeMicroseconds(n2);
    readString="";
Google forum search: Use Google Search box in upper right side of this page.
Why I like my 2005 Rio Yellow Honda S2000  https://www.youtube.com/watch?v=pWjMvrkUqX0
RoboElite
I would like to use the code I have because it works better with my design but I need both servos to rotate together, one clockwise and the other counter clockwise.
zoomkat
Quote
One way would be to subtract the current value of one servo from its max position and use the result for the other servo's position.
RoboElite
Would you be able to show me an example using my code
Code: [Select]
