Topic: Transmitting to a nearby AM radio (Read 5941 times) previous topic - next topic
smeezekitty
Feb 21, 2011, 07:57 am Last Edit: Feb 23, 2011, 11:22 pm by smeezekitty Reason: 1
I can successfully transmit tones to an AM radio nearby with this code:
void tone(int freq, int duration){
 if(freq == 0){delay(duration); return;}
 unsigned loops = (800000 / freq);
 long wait = (1000000 / freq);
 long v = (duration / ((wait*2)/1000));
 for(long k = 0;k < v;k++){
     for(unsigned i = 0;i < loops;i++){
     PORTD ^= 0x8;
   delayMicroseconds(wait);
void setup(){
   tone(440, 500); //Play A4 for 500ms
void loop(){}
The circuit is a 1K resistor from pin 3 to an antenna.
It works by actually turning the pin on and off over 800000 times per second.
Received frequency is between 880 and 890 khz.
Avoid throwing electronics out as you or someone else might need them for parts or use.
Solid state rectifiers are the only REAL rectifiers.
Resistors for LEDS!
retrolefty
Take a bow, you have invented the Arduino Marconi   ;)
smeezekitty
Now if I only knew how to read sheet music or how to send morse code.
Resistors for LEDS!
retrolefty
Well I have to think that anyone that learns to program and read in C/C++ can learn to read sheet music, not that I've tried. And sending morse code is simple, it's learning to receive it, that's a bitch.
  ._ _   ._   _....  _  _._  _..
Lefty
smeezekitty
Lefty
http://www.qrz.com/db/wa6tkd
Resistors for LEDS!
martin_bg
http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1170901754
this is some useful work on AM morse code with radio
smeezekitty
My code is better ;)
Resistors for LEDS!
RanTalbott
Follow the link in this thread: not only does he do Morse quite cleverly, but, with a name like "Kontrapunkte", he's gotta know something about music, too  ;)
keeper63
It works by actually turning the pin on and off over 800 times per second.
Shouldn't that be "800,000 times per second"?
I'm also wondering if this could possibly earn one a visit from the FCC, but I am not knowledgeable enough about RF to know whether this would cause any form interference or other issues that would have such consequences (not likely a power issue - though you could easily boost it if you wanted)...
Neat, all the same...
Onions
http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1169088394/0#0
This lets you get up to 4MHz! The code is also incredibly short, but fairly complex, unless you know lots about port manipulation and disabling interrupts.  ]:D
Onions.
My website: http://www.harryrabbit.co.uk/electronics/home.html Up and running now! (Feel free to look round!) :D
smeezekitty
Fixed.
Unlikely since the signal doesn't leave the property. The PO is < 25mw.
Resistors for LEDS!
Simpson_Jr
I'm waiting for the first DX-contest  :)
