Topic: [SOLVED] Reversing Direction and Setting Distance with AccelStepper (Read 927 times) previous topic - next topic
willduino
I am currently running a very basic program in order to try and get my stepper motor to move and accelerate how I want it to.
I am using an Arduino Uno with a DRV8825 motor driver and Nema 11 stepper.
I have activated 1/16th step resolution and done a quick sum to calculate 1 rotation of the motor = 84.2 steps = 38mm linear movement.
The short code I have written/edited SHOULD move the motor to the desired 'distanceToMove', then move it back the same distance in the opposite direction.
However, when I run the program it moves a fraction over 1 revolution, pauses for the 1 second delay, then moves 1 revolution again in the same direction.
Why is it only moving one revolution for that many steps? Why doesn't (-numberOfSteps) cause it to move in the negative direction? - I have tried simply (-12630) but it still moves in the positive direction.
Here is the code I am using;
Code: [Select]
#include <AccelStepper.h>
#define STEPPER_X_DIR_PIN 2
#define STEPPER_X_STEP_PIN 3
byte Step16 = 12; //pin 12 enables 1/16th step resolution
// 1mm = (no. of steps per rev)/(linear distance moved per rev)
// 1/16th resolution so 1mm = 3200/38 = 84.2 steps
int distanceToMove = 150; //(mm)
int numberOfSteps = distanceToMove*84.2;
// Define a stepper and the pins it will use
AccelStepper stepper;
AccelStepper stepperX(AccelStepper::DRIVER, STEPPER_X_STEP_PIN, STEPPER_X_DIR_PIN);
  pinMode(Step16, OUTPUT);
  digitalWrite(Step16, HIGH);
  stepper.setMaxSpeed(30000);
  stepper.setAcceleration(6000);
  // go forwards
  stepper.move(numberOfSteps);
  stepper.runToPosition(); // stepper shall start from speed 200, but it starts from speed 0;
  // Now go backwards
  stepper.move(-numberOfSteps);
Thanks for your help!
Will
Robin2
This calculation
Code: [Select]
will actually be calculated as
Code: [Select]
int numberOfSteps = distanceToMove*84;
because you are using integer maths
Assuming it is a 200 step motor then with 1/16th microstepping it will require 3,200 steps for one revolution.
I suggest you start simple, with full steps and get things working so it will do a full turn in both directions.
And try a very much lower maximum speed - perhaps 10 steps per second to start with. And note that the AccelStepper library cannot do very high step rates.
...R
Stepper Motor Basics
Simple Stepper Code
Two or three hours spent thinking and reading documentation solves most programming problems.
willduino
It is definitely a 200 step motor and that is what is confusing me. I set it to full step mode and told it to move to '200' but it only moves a 1/4 turn before stopping?
I was able to get it to travel to exact locations when simply running it at a fixed speed. This issue with incorrect movement has only started since trying to accelerate the motor. Any idea why this might be?
Code: [Select]
//int distanceToMove = 150; //(mm)
//float numberOfSteps = distanceToMove*84.2;
//  pinMode(Step16, OUTPUT);
//  digitalWrite(Step16, HIGH);
  stepper.setMaxSpeed(100);
  stepper.setAcceleration(10);
  // go forwards
  stepper.move(200);
//  // Now go backwards
//  stepper.move(-200);
//  stepper.runToPosition();
//  delay(1000);
Robin2
What does this version do?
Code: [Select]
  stepper.move(200);
If it still only moves one quarter turn then post a very clear diagram showing how you have everything connected.
...R
willduino
Yep just a quarter turn.. :/
Here's the diagram;
Thanks
Robin2
That seems very strange. It appears that the driver is doing 1/4 steps.
Have you tried connecting the micro-stepping pins in the arrangement that would give full steps?
...R
willduino
Full step is all three pins 'LOW' anyway but for good measure I wired them up and set them to LOW but still no difference. I tried another stepper as well but the same problem..
outsider
Have you used an Ohmeter to ID the motor leads? Wires from 1 coil to AOUT1 and AOUT2, other pair to BOUT1 and BOUT2. Can you post a link to the motor?
Robin2
Changing the motor should not make any difference.
Try a different stepper driver - my guess is that the one you have been trying has a fault.
...R
MarkT
Probably a short on the DRV8825 board or a defective chip - often these are dodgy eBay purchases,
I would not be surprized if some are counterfeit.  Generally people seem to find they are fine, but
no-one would expect high levels of quality control for such budget items!
willduino
Have tried an ohmmeter and they're definitely wired up correctly.
This is the motor;
https://www.pololu.com/product/1205
I got them in a pack of 5 and so far 3 of them have showed the exact same results.
The weird thing is that I've never experienced any problems with them doing linear motion, only trying to accelerate.
Robin2
Then post the program that works properly with linear motion
And separately post the program that uses acceleration and does not work properly so we can compare them side by side.
...R
willduino
Linear motion;
Code: [Select]
byte directionPin1 = 2;
byte stepPin1 = 3;
byte ledPin = 13;
int millisbetweenSteps = 15;
int numberOfSteps = 200;
  digitalWrite(ledPin, LOW);
  delay(2000);
  pinMode(directionPin1, OUTPUT);
  pinMode(stepPin1, OUTPUT);
  digitalWrite(directionPin1, HIGH);
  for(int n = 0; n < numberOfSteps; n++) {
    digitalWrite(stepPin1, HIGH);
    digitalWrite(stepPin1, LOW);
    delay(millisbetweenSteps);
    digitalWrite(ledPin, !digitalRead(ledPin));
Acceleration;
Code: [Select]
//byte Step16 = 12; //pin 12 enables 1/16th step resolution
  stepper.move(200);
I have also just noticed that the two programs turn the motor in opposite directions..
Robin2
Don't worry about the direction. That is easily fixed.
Just so I am completely clear, are you saying that the "linear" program causes the motor to rotate an exact revolution, pause for 1 second, and repeat?
And, the "acceleration" code causes the motor to move exactly 1/4 turn? - and obviously it does not repeat because the code is in setup()
Also, am I correct to assume that there has been no change to the wiring when you change the code?
I note that the linear program works at 66.67 steps per second (one step every 15 millisecs) and the acceleration program is set for 100 steps per second. I can't see that it makes a difference, but change the acceleration program just to make sure.
...R
willduino
Yes all of that is exactly correct.
I changed the max speed of the acceleration program to match the linear motion program but as you suspected, there was no difference there..
The project deadline that this system is intended for is approaching quite rapidly so I think I may just make a start on the positioning using 800 steps/revolution and maybe a solution will be found later..
However the other problem I encountered which I listed at the top of this thread was getting the motor to reverse direction with the AccelStepper library. Could you please indicate how this is done? As I said, I have tried moveTo(-200) for example, but the negative makes no difference to the direction of rotation.
Thanks,
Will
