Topic: Transistor (Read 4232 times) previous topic - next topic
Liz0905
hello,
I have a question about a transistor connection. I have a heating element of 50W, 12V. I realized that in order to operate it I needed a transistor to provide a sufficiently high current. Can someone please help me how I do it exactly
Thanks!
larryd
#1
Feb 19, 2018, 06:27 pm Last Edit: Feb 19, 2018, 06:31 pm by larryd
A MOSFET would be recommended.
This would be good to review.
http://www.gammon.com.au/motors
And
https://m.youtube.com/watch?t=110s&v=GrvvkYTW_0k
No technical PMs.
If you are asked a question, please respond with an answer.
If you are asked for more information, please supply it.
If you need clarification, ask for help.
tinman13kup
If you apply ohms law to your heating element, you are going to have a little over 4.1A into that heater. It's not that it is huge by any means, unless you pick the wrong components to deal with it and they simply go up in a little stinky smoke cloud. Watch the heat dissipation.
Tom
It's not a hobby if you're not having fun doing it. Step back and breathe
Liz0905
Okay, I already realized that I needed to use a MOSFET transistor. If I use five heating elements I have to put a transistor in front of each one? How do I know how much current a transistor is going to provide me? And if I do not want to reach temperatures are too high, let's say 50 degrees? Am I using the resistor? And if so, where in the electric circuit do I place it? ... If I understand correctly, i don't need to change my code, I just do a high / low with digitalwrite?
Thanks you very much!
MarkT
Never use resistors for controlling power, that's just waste.  PWM is used for controlling power.  The duty
cycle sets the average power without having any unnecessary waste heat to git rid of.
Firstly to control a MOSFET directly from an Arduino requires a logic-level MOSFET, this is mandatory unless
you want to level-shift to 12V.
MOSFETs are picked by max voltage and on-resistance.   The on-resistance determines the dissipation
for a given current load.
You can switch 5 heating elements in parallel if you want, that's simpler.  Is each one 50W, or the total 50W?
What is the resistance of each heating element? (ie have you calculated that 50W correctly)
[ I DO NOT respond to personal messages, I WILL delete them unread, use the forum please ]
Liz0905
Thank you,
I use those heating elements:
https://he.aliexpress.com/item/AC-DC-12V-50W-Thermostat-PTC-Aluminum-Electric-Heater-Plate-Heating-Plate-Hair-Censer-Insulation-Mayitr/32812392601.html?spm=a2g16.10010108.1000015.15.3d85d6e8UhCjvQ
and i thought use:
https://www.sparkfun.com/products/10213
I have to be able to provide a current for some of the five at the same time or all of them together
Thanks!
Liz0905
If i use a 9V battery for the Arduino, do i need one more battery for my heating elements?!
Thank you.
MarkT
So you want individual control, ie 4A for each MOSFET, those Sparkfun ones are OK, but overkill on
the 60V rating, 30V MOSFETs have lower on-resistance.
0.05ohm x 4^2 = 0.8W per MOSFET, so a small heatsink is indicated.  Get some 10 milliohm 30V
MOSFETs and no heatsinking needed.
To switch all of them together is 20A which is beyond those MOSFETs as I said earlier, <=5 milliohm is
a good figure for that, a bit harder to find as logic-level, but they exist down to about 2 milliohm last
time I checked.
MarkT
Thank you.
5 50W heaters = 250W.  That's serious power.  Standard 9V batteries are good for 0.5W, and are
not 12V!
You should explain what you are trying to do, battery power for heating is usually not a sensible
approach.
Liz0905
not 12V!
approach.
I'm trying to do a heating glove
Grumpy_Mike
Quote
Seriously?
Having 250W in to one hand is going to be an instant barbecue.
Liz0905
Seriously?
That's exactly why I said that of course I should not have the maximum power! And not reach temperatures so high!
Grumpy_Mike
You have the wrong heating pad for this design.
Liz0905
And if we assume that I must use this specific element
Grumpy_Mike
Then you should not do the project.
