Topic: Transistor (Read 3270 times) previous topic - next topic
posbuild
#45
Sep 11, 2018, 11:50 pm Last Edit: Sep 12, 2018, 12:47 am by posbuild
250W is crazily high and will burn you.
1W will do nothing.
So 10W is about right as a starting point for designing a warmer like this.  Perhaps it should be 20W,
perhaps not, you need to experiment.  Remember a lot of soldering irons use 40W or less...
I'm intrigued by the project and wanted to see what I could make and get a feel for what wattage a glove heater might need to be. I etched a heater from polyimide film using material that I requested for free from Dupont's website:
http://www.dupont.com/products-and-services/membranes-films/polyimide-films/sample-request-kapton.html
The heater I made was this spiral thingie (see picture below) that I then cut up to be one long heater. It has a resistance of 3.5 ohms. It is just long enough to wrap around each of five fingers.
I'm powering it with an old weedeater battery that limits current to 1.5A. The battery is 20V so I'm using a buck converter to take it down to 6V.
To test I wore a thin cotton glove and then wrapped one finger with the heater and turned it on. I could feel it warm up quickly but didn't get too hot. If I put this assembly inside of a winter glove I think it would work even better. At 9 watts it's just right for my tastes.
A thought I had was to adhere the polyimide heater to the glove with thermal glue and then spray it with plasti-dip to give it a rubber coating and make it more water resistant. It would sort of be a hybrid of two different flexible heaters.
MarkT
You heated glove prototype is much more efficient at heating the air than your hand.  The outside of
the heater coil should be well insulated thermally, and the power can then be dropped.
posbuild
Nice. I wonder how low I could go with power and still have sufficiently useful warming. I'll try putting it inside a good ski glove finger first and then maybe I'll try dipping or spraying with rubber.
MarkT
I think you'll have to do some experimentation with a gloved hand in an icebox!
allanhurst
What's wrong with good ole' NiChrome wire?
Allan
MarkT
Well nichrome wire isn't insulated so you'd need to arrange that, and its probably
overkill (you aren't needing fairly constant resistance upto orange heat!)
Steel wire has a reasonable amount of resistance, is available insulated (for garden use
like plant ties), and is cheap and tough.  Stainless steel wire also.
