Topic: box Lock (Read 262 times) previous topic - next topic
William03
I'm planning on creating some sort of storage lock box, but I am stuck, I don't know what to use as a lock I saw some people use servos but I believe that is not efficent do you guys know of any better way?
Isaac96
Why isn't a servo efficient? You can use a simple slide bolt and a cheap servo and make a strong lock. If you want to go overkill, a solenoid would work, but be slightly harder to match travel-wise.
Do not PM me for help. I will delete immediately.
CONNECT THE GROUNDS!
After Tuesday, even the calendar goes W T F
larryd
Quote
Explain what you mean by this.
No technical PMs.
The last thing you did is where you should start looking.
aman59
Hey,
You can use electromagnet lock or an actuator.
The above things can be easily controlled using an arduino.
Hope this helps
William03
thanks for sharing, ill prob use an electric one
