Topic: Clearing RX Serial Buffer (Read 217 times) previous topic - next topic
Gosucherry
Hi!
I would like to write a function which clears my RX buffer. And I know the most obvious answer:
Code: [Select]
void ClearBuffer(){
  while(Serial.available()){
    Serial.read();
But in my application, I have to do this MUCH faster than just reading all data. Arduino hardware serial uses RX ring/circular buffer - so I would like to simply override buffer head address with buffer tails address . If im thinking right, this would be the fastest way of clearing rx buffer, but I cant really find any information about those tail/head addresses. Any advices on that?
Robin2
What you have posted is how I would do it.
How long do you think that piece of code takes to complete?
How quickly (in microseconds) do you need to clear the buffer?
...R
Two or three hours spent thinking and reading documentation solves most programming problems.
robtillaart
you could patch the HardwareSerial.h /.cpp to add a function
void HardwareSerial::clearRXBuffer()
  _rx_buffer_head =  _rx_buffer_tail;
faster than that is diificult.
Rob Tillaart
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
(Please do not PM for private consultancy)
robtillaart
A non-core patch version could be
Code: [Select]
void clearRXBuffer()
  int x;
  while (x = Serial.available() > 0)
     while (x--) Serial.read();
the advantage is that available() is called far less so should be (max 2x) faster.
Rob Tillaart
Gosucherry
...R
My application is based on very precise time windows, which are set to 500uS. Since I was having a 40 bytes in RX buffer I had to waste lot of time discarding it ( over 300uS ). Why do I have stuff in RX buffer that I dont want to read? Its because I'm making multiple nodes ( Arduino Unos ) talking over MAX485 in order :)
This is the very thing I was looking for! Thank you. It takes ~8uS :)
robtillaart
Created an issue for this improvement - https://github.com/arduino/Arduino/issues/7254
Rob Tillaart
