Topic: avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x00 (Read 109421 times) previous topic - next topic
freddie43
pert. I am away from home at the moment so I do not have access to a Nano or an IDE.
I do hear what you say and I accept it. But what I am saying is that however it got there, the first time I hit the problem was when I updated the  IDE from 1.8.5 to 1.8.7. That is my experience and you cannot deny that is why I see things the way I do (and probably why others do too). If I had not updated I would not have known of the problem or be in this thread. But thank you for the explanation of how and when it got there. I am grateful for your clarification of how it got there, but can we leave it at that?
By comparison David Prentice has managed to identify the wide range of controller chips that are put on seemingly identical mcufriend TFT LCD shields and has worked hard to provide software to drive them all.
Sadly, unlike my genuine Arduinos, all my clone Nano, Uno and Mega boards seem to have the same onboard refs, so there is no s/w way to identify them and treat them correctly and change the way the IDE handles them.
But the real problem is as Robin2 says in my other thread: Arduino developers seem to have very little interest in backwards compatibility.
Greybeard programmer since the dawn of time.
Much enjoying the challenges of Arduino.
pert
The solution is to just burn whichever bootloader you want to them. Then there is no need to do any identification. I prefer to use the Uno's configuration, since this frees up 1.5 kB of flash memory:
  • Connect an ISP programmer to the nano. If you don't own an ISP programmer, you can use an Arduino board as an "Arduino as ISP".
  • Tools > Board > Arduino/Genuino Uno
  • Tools > Programmer > select the appropriate programmer
  • Tools > Burn Bootloader
After doing this, you should use your Nano as an Uno.
It is true they could have changed the bootloader and fixed the watchdog bug of the old one without breaking compatibility. The only downside compared to what they did do is needing to stay with the slower upload speed of the old bootloader. Or they could have broken compatibility, but changed the boot section to 0.5 kB instead of the unnecessary 2 kB they are using now. So we ended up with the worst of each option: Breakage, without reaping the most important potential benefit of the change. It would be interesting to know the story of how that came about. I suspect this one was not a decision made by the developers, but someone in management or manufacturing. I pointed out the issue immediately after the change was made to Arduino AVR Boards but by that time they had already made a bunch of Nanos with the new configuration so fixing it would have required either doing the right thing and recalling all the misconfigured Nanos from their distributors or else doing the hacky thing and adding yet another Nano configuration option. Instead, they decided to stick with the mistake and continue to produce Nanos with the suboptimal new configuration.
freddie43
pert Funny you should say that about burning a bootloader, as that was what I did when my clone Unos seemed to play up after the IDE upgrade. There is a very useful 'Instructables' post on 'How to fix bad Chinese clones' which I used to cope with the CH340 problem when I first bought  a clone. This time I did Uno to Uno as well as reinstalling CH340. Didn't realise I could do Uno to Nano. Fascinating!
Thanks too for the second part of your post. Really interesting.
jaggermad
I had this problem yesterday with my nanos... I solve it to downgrading to AVR Boards 1.6.20. A temporal solution... I guess.
genius, thank you very much
pert
No, it's not at all genius. It's actually a very bad solution. The much better solution (as I have already explained) is to use the up to date version of Arduino AVR Boards, and select Tools > Processor > ATmega328P (Old Bootloader).
milanstekly
The problem as it occurs with uploading to Nano with Arduino AVR Boards 1.6.21 can be solved by simply selecting Tools > Board > ATmega328P (Old Bootloader). There's no need to uninstall or downgrade anything.
The problem as it occurs for other boards will have a different cause and a different solution.
Selecting old bootloader would be simple if there was such an option. (I use the Linux version of the IDE.) Can you help me?
pert
If there is no Tools > Board > ATmega328P (Old Bootloader) menu option, that means you're using a version of Arduino AVR Boards older than 1.6.21. If so, then the Tools > Processor > ATmega328 menu selection is the exact equivalent of Tools > Board > ATmega328P (Old Bootloader) when using Arduino AVR Boards 1.6.21 or newer. If you have no Tools > Processor menu, then that means you're using an extremely outdated version of the Arduino IDE.
I'll need some additional information in order to help you:
Are you using a Nano?
Is it an official Arduino Nano or one of the cheaper ones made by other companies?
If it's an official Nano, when did you buy it?
serge2010
Hi guys,
I have exactly the same issue with by banggood - arduino nano copy. I've tried using the old bootloader and also installed the chinese drivers - still not working.
Please help me.
Details:
1) Product: https://eu.banggood.com/Wholesale-Warehouse-ATmega328P-Nano-V3-Controller-Board-Compatible-Arduino-wp-Eu-940937.html?rmmds=search
2) My settings: Tools > Board > Arduino Nano; Tools > Processor > ATmega328P (Old Bootloader)
3) Drivers: https://www.instructables.com/id/How-to-fix-bad-Chinese-Arduino-clones/
4) Error message:
Arduino: 1.8.9 (Windows Store 1.8.21.0) (Windows 10), Board: "Arduino Nano, ATmega328P (Old Bootloader)"
Sketch uses 494 bytes (1%) of program storage space. Maximum is 30720 bytes.
Global variables use 9 bytes (0%) of dynamic memory, leaving 2039 bytes for local variables. Maximum is 2048 bytes.
the selected serial port avrdude: stk500_recv(): programmer is not responding
 does not exist or your board is not connected
C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wtt\hardware\tools\avr/bin/avrdude -CC:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wtt\hardware\tools\avr/etc/avrdude.conf -v -patmega328p -carduino -PCOM4 -b57600 -D -Uflash:w:C:\Users\Serg\AppData\Local\Temp\arduino_build_26314/eeprom_clear.ino.hex:i
avrdude: Version 6.3-20171130
         Copyright (c) 2007-2014 Joerg Wunsch
         System wide configuration file is "C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wtt\hardware\tools\avr/etc/avrdude.conf"
         Using Port                    : COM4
         Using Programmer              : arduino
         Overriding Baud Rate          : 57600
         AVR Part                      : ATmega328P
         Chip Erase delay              : 9000 us
         PAGEL                         : PD7
         BS2                           : PC2
         RESET disposition             : dedicated
         RETRY pulse                   : SCK
         serial program mode           : yes
         parallel program mode         : yes
         Timeout                       : 200
         StabDelay                     : 100
         CmdexeDelay                   : 25
         SyncLoops                     : 32
         ByteDelay                     : 0
         PollIndex                     : 3
         PollValue                     : 0x53
         Memory Detail                 :
                                  Block Poll               Page                       Polled
           Memory Type Mode Delay Size  Indx Paged  Size   Size #Pages MinW  MaxW   ReadBack
           eeprom        65    20     4    0 no       1024    4      0  3600  3600 0xff 0xff
           flash         65     6   128    0 yes     32768  128    256  4500  4500 0xff 0xff
           lfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           hfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           efuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           lock           0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           calibration    0     0     0    0 no          1    0      0     0     0 0x00 0x00
           signature      0     0     0    0 no          3    0      0     0     0 0x00 0x00
         Programmer Type : Arduino
         Description     : Arduino
         Hardware Version: 2
         Firmware Version: 1.16
avrdude: stk500_getparm(): (a) protocol error, expect=0x14, resp=0xfc
         Vtarget         : 0.0 V
         Varef           : 0.0 V
         Oscillator      : 3.686 MHz
         SCK period      : 0.1 us
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.00s
avrdude: Device signature = 0x1e950f (probably m328p)
avrdude: reading input file "C:\Users\Serg\AppData\Local\Temp\arduino_build_26314/eeprom_clear.ino.hex"
avrdude: writing flash (494 bytes):
Writing | ################################################## | 100% 0.15s
avrdude: 494 bytes of flash written
avrdude: verifying flash memory against C:\Users\Serg\AppData\Local\Temp\arduino_build_26314/eeprom_clear.ino.hex:
avrdude: load data flash data from input file C:\Users\Serg\AppData\Local\Temp\arduino_build_26314/eeprom_clear.ino.hex:
avrdude: input file C:\Users\Serg\AppData\Local\Temp\arduino_build_26314/eeprom_clear.ino.hex contains 494 bytes
avrdude: reading on-chip flash data:
Reading | avrdude: stk500_recv(): programmer is not responding
############avrdude: stk500_recv(): programmer is not responding
avr_read(): error reading address 0x0000
    read operation not supported for memory "flash"
avrdude: failed to read all of flash memory, rc=-2
avrdude done.  Thank you.
option enabled in File -> Preferences.
serge2010
I also found this line in the config file called "avrdude"
Line: # There is a ATmega328P kit PCB called "uncompatino".
Could this be the issue? I don't know how to delete it, as it says I had no admin rights.
thehardwareman
Happened to me today. I have several  UNO 3 boards. The last one I tried I got this errors:
Code: [Select]
Arduino: 1.8.9 (Windows 7), Board: "Arduino/Genuino Uno"
Sketch uses 5220 bytes (16%) of program storage space. Maximum is 32256 bytes.
Global variables use 522 bytes (25%) of dynamic memory, leaving 1526 bytes for local variables. Maximum is 2048 bytes.
C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avrdude -CC:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf -v -patmega328p -carduino -PCOM11 -b115200 -D -Uflash:w:C:\Users\dahls\AppData\Local\Temp\arduino_build_337231/i2c-scanner.ino.hex:i
         System wide configuration file is "C:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf"
         Using Port                    : COM11
         Overriding Baud Rate          : 115200
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x9e
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x9e
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x9e
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x9e
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x9e
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x9e
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x9e
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x9e
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x9e
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x9e
Problem uploading to board.  See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.
It started while trying to set up a new sketch using several I2C units. I managed to upload the i2c_scanner before it stopped. So on one board the i2c_scanner is running and I have no problem getting data from it using the serial monitor.
thehardwareman
Strange. I switched back to the UNO 3 with the i2c_scanner installed. It just start working again. And it was while using this UNO 3 the problem started.
I'm glad it works, but I would like a good explanation why it fail and why it start working again.
thehardwareman
Adam was not long in paradise. It seems like I can upload the same sketch that is already loaded, but not a new one.
Code: [Select]
Sketch uses 9556 bytes (29%) of program storage space. Maximum is 32256 bytes.
Global variables use 519 bytes (25%) of dynamic memory, leaving 1529 bytes for local variables. Maximum is 2048 bytes.
C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avrdude -CC:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf -v -patmega328p -carduino -PCOM10 -b115200 -D -Uflash:w:C:\Users\dahls\AppData\Local\Temp\arduino_build_922921/ntc_mux_test.ino.hex:i
         Using Port                    : COM10
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x00
An error occurred while uploading the sketch
So now I do not what to do. I have googled this error but non of the suggestions seem to work.  :o
thehardwareman
What the F** is happening?? I upgraded the IDE to 1.8.10 (latest available version).
I switch to another UNO 3. This time I was able to upload the sketch. It seems to work OK.
Then I modified the code and the failure is back again but now with a different resp code.
Code: [Select]
Arduino: 1.8.10 (Windows 7), Board: "Arduino/Genuino Uno"
Sketch uses 9752 bytes (30%) of program storage space. Maximum is 32256 bytes.
Global variables use 555 bytes (27%) of dynamic memory, leaving 1493 bytes for local variables. Maximum is 2048 bytes.
C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avrdude -CC:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf -v -patmega328p -carduino -PCOM12 -b115200 -D -Uflash:w:C:\Users\dahls\AppData\Local\Temp\arduino_build_892110/ntc_mux_test.ino.hex:i
avrdude: Version 6.3-20190619
         Using Port                    : COM12
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x7a
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x7a
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x7a
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x7a
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x7a
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x7a
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x7a
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x7a
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x7a
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x7a
I then reset the UNO 3 and tried again. Now I get a different resp code.
Code: [Select]
         Using Port                    : COM12
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x16
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x16
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x16
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x16
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x16
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x16
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x16
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x16
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x16
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x16
SteffenDue
Bei mir hat beim Arduino Nano der Tipp mit Einstellung
geholfen.
Danke.
AdiDaBoss
Hello, I have the same issue but with an Arduino Uno. The details are as follows:
1. Board - Arduino UNO R3 Board Atmega328p Ch340g
2. Code - First I tried to program with a L298n H-Bridge and a DC Motor however, I have disconnected all wires and tried to upload the blink code but it still does not work.
3. Arduino IDE : The latest version, 1.8.10 and I downloaded the IDE through both Windows zip folder and Windows installer
Here is the error message:
Code: [Select]
Arduino: 1.8.10 (Windows 10), Board: "Arduino/Genuino Uno"
Sketch uses 2422 bytes (7%) of program storage space. Maximum is 32256 bytes.
Global variables use 188 bytes (9%) of dynamic memory, leaving 1860 bytes for local variables. Maximum is 2048 bytes.
C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avrdude -CC:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf -v -patmega328p -carduino -PCOM3 -b115200 -D -Uflash:w:C:\Users\Kumars\AppData\Local\Temp\arduino_build_524254/RBT_Project.ino.hex:i
         Using Port                    : COM3
I have tried uninstalling and reinstalling the Arduino IDE, changing the USB cable, using an official Arduino UNO board etc. I have seen most of the threads but none of the tips seem to have worked. Just a few weeks ago the Uno board uploaded fine but suddenly it has stopped working.
I would sincerely appreciate any help on the matter. Thank you very much
Aditya
