Topic: EXPLANATION: SERVO vs SERVO MOTOR and driver (Read 2711 times) previous topic - next topic
lastchancename
Feb 22, 2018, 11:24 am Last Edit: Sep 05, 2019, 06:16 pm by lastchancename
Just to help explain a simple but often misquoted concept.
A SERVO is a closed-loop control system.
It may _not_ be a motor, but typically is*, using feedback to create a stable, deterministic output from the controlled device.
Example
You provide a reference, and the servo control system varies the output to equalise the feedback with the reference value.
* it /could/ be a fluid servo that maintains the specific level in a tank..
Many servo systems utilise MOTORS to delver mechanical output.
It /could/ be a STEPPER motor with step-counting, limits, feedback and drivers to achieve the desired motion control,
OR in ArduinoLand...
the MOTOR might well be a generic DC motor, with attached feedback electronics to achieve a simpler type of low-cost closed-loop control.
This is typically what is inside your *RC 'hobby' servo*.
Example
The reference is a pulse-train which the motor driver 'chases' while moving the motor shaft - providing feedback to the 'closed-loop' driver to maintain equilibrium.
Some gearing is often provided to deliver reasonable torque, speed and stability at low cost.
Experienced responders have a nose for laziness, (they were beginners once)... Sure, there are trolls, chest-beaters, and pretenders - but the help you'll get here is about as good as it gets - if you try to help youself!.
losmi
Okay, could you please post some concrete models/images to illustrate these SERVO types?
lastchancename
#2
May 04, 2018, 06:24 pm Last Edit: May 04, 2018, 06:24 pm by lastchancename
A SERVO is not a type, it is a process.
SERVO refers to a closed-loop control methodology.
In the case of an RC hobby servo, the control process is contained *within* that small box with three wires and an output shaft.
Other 'servos' may be a free spinning motor with an encoder on the shaft. In that case the servo functionality is implemented by the control process between the encoder and the motor driver...
It may control motor speed and/or angular positioning as needed.
...or a cistern that stops overflowing - with a float valve that controls the flow rate and/or on/off valve state.
slipstick
Too much theory, not enough practical. To an Arduino beginner the important difference is between a (hobby type) servo and a motor.
A servo can be sent to a particular position, usually an angle. Most servos will only move through about 130-180 degrees though there are exceptions. Typically used for steering things or moving controls.
A motor is a thing that rotates round and round. You can usually control the direction and speed of rotation but you can't position it accurately without some additional equipment , typically an encoder. Often used for driving wheels to make cars, robots etc move.
Much confusion is caused because, for some unknown reason, a lot of Arduino documentation refers to servos as "servo motors".
And to add to the confusion some servos can be converted to what are often called 360 degree or continuous rotation when they spin continuously and you lose the ability to position them. In other words they are no longer servos they are just (geared) motors.
Steve
lastchancename
#4
May 12, 2018, 12:14 am Last Edit: May 12, 2018, 12:14 am by lastchancename
You're welcome to post some extra content ;)
Be careful of your terminology, just because an (RC)servo can be driven to a particular angle, don't dismiss 'servo motors' ...
...because that's *exactly* what's inside an RC servo!
It's that extra glue that makes a very important distinction.
Thanks for making me clarify that point!
slipstick
Be careful of your terminology, just because an (RC)servo can be driven to a particular angle, don't dismiss 'servo motors' ... ...because that's *exactly* what's inside an RC servo!
One the things inside a servo is indeed a motor. But that's not a good reason enough for referring to the whole servo as though it was just a motor.
My car contains a fuel tank but if I talked about going for a drive in my car fuel tank people would look at me very strangely.
Steve
lastchancename
#6
May 16, 2018, 01:38 am Last Edit: May 16, 2018, 01:41 am by lastchancename
Post #2 clarifies that.
As they rightly should !
There *are* exceptions
Metron_Ross
Steve
Steve,
You are missing the OP's important point.  Many people have been misled by imprecise writers into thinking that a "Servo" is a type of motor.
Along those lines, you described the entire universe of possible servos as if that universe only contains rotating pointers.  The meaning of the word "servo" encompasses way more topics than just devices that can do that.
The OP isn't referring to the "whole servo as if it was just a motor."  He is saying that while servos often contain one or more motors of one sort or another, they are not a type of motor.
If I'm understanding you correctly, earlier you were describing a servo mechanism, that probably contained some sort of electric motor.  However, despite what many might think, the OP and I are pointing out that that mechanism isn't a servo-motor.
To further clarify the point, consider this, if you study types of motors, in a properly written textbook or other source, you won't find a "servo motor" type of motor.  Why? Because a servo isn't a type of motor.  A servo is (generally) a collection of things used to control an output, and none of those things have to be a motor, much less some specific type of electric motor.
It's common mistake, reinforced by plenty of imprecise literature and vendors' ads.  The Arduino Servo library's documentation is an example of that sort of imprecise writing.
lastchancename
slipstick
Well I hope that any newcomers trying to read these convoluted explanations are less confused by them than I am. But I doubt it.
I'll say it again....too much blinding people with the theory of "the whole universe of things that might be called servos/servo motors/servo mechanisms" and too little consideration of the type of things that 99.99% of people actually meet and are talking about.
If I could just persuade people (including those who write some of the Arduino technical information) to stop calling hobby servos "servo motors" I'd be happy enough.
Steve
Metron_Ross
How about this:
No matter what any vendor or naive person says, a "Servo" is device that often *contains* a motor (and other things), and is *not* a type of motor.
Devices called "Servo Motors" by many, many hobbyists, are actually Servos that *contain* Motors and other things.
That's not so convoluted, is it?
