Topic: POST HTTP SENDER (Read 773 times) previous topic - next topic
Giovax
Feb 23, 2018, 06:16 pm Last Edit: Feb 23, 2018, 11:30 pm by Giovax
Good. I really do this for the last option.
I have already tried several days to send a successful post petition to a web service.
I did it with the WCF client, create an application in c # that consumed it and everything works fine. Except with arduino. This is the shipping code, using arduino UNO and Ethernet shield2
Code: [Select]
 Serial.println("In SOPA");
    Serial.println("Connected to Server");
    client.println(F("POST /WS_PLANILLA.Service1.svc?wsdl HTTP/1.1"));
    client.println(F("Host:192.168.0.101:8312"));
    client.println(F("Content-Type:text/xml; charset=utf-8"));
    client.println(F("Content-Length:215"));
    client.println();
    client.print(F("<s:Envelope xmlns:s=\"http://schemas.xmlsoap.org/soap/envelope/\">"));
    client.print(F("<s:Header>"));
    client.print(F("<Action s:mustUnderstand=\"1\" xmlns=\"http://schemas.microsoft.com/ws/2005/05/addressing/none\">http://tempuri.org/IService1/ConsultaID</Action>"));
    client.print(F("</s:Header>"));
    client.print(F("<s:Body>"));
    client.print(F("<ConsultaID xmlns=\"http://tempuri.org/\"/>"));
    client.print(F("</s:Body>"));
    client.print(F("</s:Envelope>"));
    client.println();
    Serial.println("MAKE REQUEST DONE");[/sup]
and the response:
[sup]connecting...
192.168.0.103
In SOPA
Connected to Server
MAKE REQUEST DONE
HTTP/1.1 400 Bad Request
Server: Microsoft-IIS/10.0
X-Powered-By: ASP.NET
Date: Fri, 23 Feb 2018 17:10:32 GMT
Content-Length: 0
Content-Type: text/html; charset=us-ascii
Server: Microsoft-HTTPAPI/2.0
Connection: close
Content-Length: 326
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01//EN""http://www.w3.org/TR/html4/strict.dtd">
<HTML><HEAD><TITLE>Bad Request</TITLE>
<META HTTP-EQUIV="Content-Type" Content="text/html; charset=us-ascii"></HEAD>
<BODY><h2>Bad Request - Invalid Verb</h2>
<hr><p>HTTP Error 400. The request verb is invalid.</p>
</BODY></HTML>
disconnecting.
Any help is welcome
christop
If I'm counting it right, your request body is longer than 215 bytes. It's more like 299 bytes.
Giovax
the number of the request must be exact ??
and thanks for the answer
Giovax
#3
Feb 23, 2018, 10:02 pm Last Edit: Feb 23, 2018, 11:31 pm by Giovax
Here I have new information. I put the correct amount. That message I was sending was the one generated by the WCF client, change it by the message generated by SOAPUI, which is what I use in a C # application that I did to test this.
It is the following:
Code: [Select]
   client.println(F("Content-Length:201"));
   client.println();
   client.print(F("<soapenv:Envelope xmlns:soapenv=""http://schemas.xmlsoap.org/soap/envelope/"" xmlns:tem=""http://tempuri.org/"">"));
   client.print(F("<soapenv:Header/>"));
   client.print(F("<soapenv:Body>"));
   client.print(F("<tem:ConsultaID/>"));
   client.print(F("</soapenv:Body>"));
   client.print(F("</soapenv:Envelope>"));
   client.println();
   Serial.println("MAKE REQUEST DONE");"
The problem is that now I do not receive any response, as if it was not sent.
"connecting...
192.168.0.103
In SOPA
Connected to Server
MAKE REQUEST DONE
disconnecting.
PieterP
Of course not, you don't have any code that would read or show the response.
Pieter
Giovax
#5
Feb 23, 2018, 11:21 pm Last Edit: Feb 23, 2018, 11:30 pm by Giovax
Sorry. The misunderstanding is because I have only posted the POST shipping code, here we show full
Code: [Select]
#include <SPI.h>
#include <Ethernet2.h>
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
byte server[] = { 192, 168, 0, 101 };
// Set the static IP address to use if the DHCP fails to assign
IPAddress ip(192, 168, 0, 177);
// Initialize the Ethernet client library
// with the IP address and port of the server
// that you want to connect to (port 80 is default for HTTP):
EthernetClient client;
while (!Serial) {
  ; // wait for serial port to connect. Needed for native USB port only
// start the Ethernet connection:
if (Ethernet.begin(mac) == 0) {
  Serial.println("Failed to configure Ethernet using DHCP");
  // try to congifure using IP address instead of DHCP:
  Ethernet.begin(mac, ip);
// give the Ethernet shield a second to initialize:
Serial.println("connecting...");
Serial.println(Ethernet.localIP());
// if you get a connection, report back via serial:
if (client.connect(server, 8312)) {
      soapEnvelope();
  // if you didn't get a connection to the server:
  Serial.println("connection failed");
String soapEnvelope()
  client.println(F("Content-Length:204"));
  client.println();
  client.println();
// if there are incoming bytes available
// from the server, read them and print them:
if (client.available()) {
  char c = client.read();
  Serial.print(c);
// if the server's disconnected, stop the client:
if (!client.connected()) {
  Serial.println("disconnecting.");
  client.stop();
  // do nothing forevermore:
  while (true);
PieterP
There's no guarantee that there's data available to read when entering the loop.
Code:
  while (client.connected()) {
      Serial.print(c);
  client.stop();
  while (true);
You'll probably have to add a "Connection: close" header in your request.
Giovax
I am very thankfull for your help.
I added the closing tag, in fact I had already done it in other tests, only that they were so many that I had forgotten.
But I still do not get an answer.
P.D: How do you make the color code?
Code: [Select]
#include <SPI.h>
  while (!Serial) {
        soapEnvelope();
    client.println(F("Connection: close"));
    client.println();
    client.println();
    Serial.print(c);
    client.stop();
    while (true);
Giovax
Well I have published the same WS, which only has one method that returns "4" in the following address. In case you can help something.
http://52.36.59.165:8312/WS_PLANILLA.Service1.svc?wsdl
PieterP
Giovax
#10
Feb 24, 2018, 01:19 am Last Edit: Feb 24, 2018, 02:30 am by Giovax
Yes.Iam Sorry, that I uploaded the wrong code.
Code: [Select]
#include <SPI.h>
  while (!Serial) {
        soapEnvelope();
    client.println(F("POST /WS_PLANILLA.Service1.svc HTTP/1.1"));
    client.println();
    client.println();
      Serial.print(c);
  client.stop();
  while (true);
But i got the same result
Giovax
Look, I do not understand this. If I change the connection tag I receive the following error:
CODE:
Code: [Select]
#include <SPI.h>
  while (!Serial) {
        soapEnvelope();
    client.println("");
        client.println("");
      Serial.print(c);
  client.stop();
  while (true);
ANSWER:
connecting...
192.168.0.103
In SOPA
Connected to Server
MAKE REQUEST DONE
Date: Mon, 26 Feb 2018 15:02:23 GMT
Content-Length: 0
And that's fine, the request is wrong, but if I put the connection tag where it should be, I simply do not receive anything.
CODE
Code: [Select]
#include <SPI.h>
  while (!Serial) {
        soapEnvelope();
    client.println("");
        client.println("");
      Serial.print(c);
  client.stop();
  while (true);
ANSWER:
connecting...
192.168.0.103
In SOPA
Connected to Server
MAKE REQUEST DONE
PieterP
That's very strange ... I'm afraid I can't help you. Did you try sending the request using cURL or netcat?
Giovax
To test if the Ws works ???. I already tested it with WCF client and a small application in c # I did.
But doing more tests I have another interesting example. look at this code
Code: [Select]
#include <SPI.h>
  while (!Serial) {
        soapEnvelope();
    client.println(F("SOAPAction: http://tempuri.org/IService1/ConsultaID"));
    client.println(F("Accept: text/xml"));
    client.println(F("Content-Length: 212"));
    client.println(F("Expect: 100-continue"));
    client.println("");
      Serial.print(c);
  client.stop();
  while (true);
missing the line break after the header. And I get this error:
connecting...
192.168.0.103
In SOPA
Connected to Server
MAKE REQUEST DONE
Date: Mon, 26 Feb 2018 17:18:51 GMT
Connection: close
Content-Length: 339
<BODY><h2>Bad Request - Invalid Header</h2>
<hr><p>HTTP Error 400. The request has an invalid header name.</p>
</BODY></HTML>
disconnecting.
But if I put it in, again I do not get anything
connecting...
192.168.0.103
In SOPA
Connected to Server
MAKE REQUEST DONE
 :o  :o  :o  :o
Thanks for all the help
Giovax
#14
Feb 26, 2018, 06:45 pm Last Edit: Feb 26, 2018, 06:51 pm by Giovax
more data, look what happens if I remove the label
  client.println(F("Content-Length: 212")); :
connecting...
192.168.0.103
In SOPA
Connected to Server
MAKE REQUEST DONE
HTTP/1.1 411 Length Required
Date: Mon, 26 Feb 2018 17:43:38 GMT
Connection: close
Content-Length: 344
<HTML><HEAD><TITLE>Length Required</TITLE>
<BODY><h2>Length Required</h2>
<hr><p>HTTP Error 411. The request must be chunked or have a content length.</p>
</BODY></HTML>
disconnecting.
The problem is obvious. I just do not understand why if you put the label it just does not respond
