Topic: Servo motor and gyroscope  (Read 885 times) previous topic - next topic
jbraightmeyer
Feb 23, 2018, 09:52 pm Last Edit: Feb 23, 2018, 10:02 pm by jbraightmeyer
Is there a way to get one servo to rotate counterclockwise. And the other to rotate clockwise while still using the same axis of the gyroscope. I am operating 2 servos with a mpu6050.
vinceherman
Yes.  Write a value to one servo that turns it CCW.  Write a different value to the other servo that turns it CW.
Quote
I am *guessing* that you are using the output of one axis of a gyro to control the servo behavior.  You will probably have to do a bit more describing of how the gyro values control the servos.
jbraightmeyer
#2
Feb 23, 2018, 10:10 pm Last Edit: Feb 23, 2018, 10:15 pm by jbraightmeyer
I am very new to programming so I can't really explain the values. I will try to upload my code so you can understand what i am trying to do.
vinceherman
Good idea.
And since you are new, go read through the How to use this forum - please read sticky post that has much great info for new members.
jbraightmeyer
So I ended up using  this guys code and editing it to work 4 servos. https://maker.pro/education/diy-constant-current-source-power-supply-circuit
For some reason it isnt letting me attach a picture of my code
vinceherman
Don't attach a picture of code.  Post the code using code tags, as is fully documented in the sticky post I linked to in reply #3 above.
jbraightmeyer
Here is the code ive been using
Code: [Select]
#include <Wire.h>
#include <MPU6050.h>
#include <Servo.h>
Servo sg90;
Servo sg91;
Servo sg92;
Servo sg93;
int servo_pin0 = 8;
int servo_pin1 = 9;
int servo_pin2 = 10;
int servo_pin3 = 11;
MPU6050 sensor ;
int16_t ax, ay, az ;
int16_t gx, gy, gz ;
void setup ( )
sg90.attach ( servo_pin0 );
sg91.attach ( servo_pin1 );
sg92.attach ( servo_pin2 );
sg93.attach ( servo_pin3 );
Wire.begin ( );
Serial.begin  (9600);
Serial.println  ( "Initializing the sensor" );
sensor.initialize ( );
Serial.println (sensor.testConnection ( ) ? "Successfully Connected" : "Connection failed");
delay (1000);
Serial.println ( "Taking Values from the sensor" );
delay (1000);
void loop ( )
sensor.getMotion6 (&ax, &ay, &az, &gx, &gy, &gz);
ax = map (ax, -17000, 17000, 0, 180) ;
ay = map (ay, -17000, 17000, 0, 180) ;
Serial.println (ax);
Serial.println (ay);
void reverse() {
sg90.write (ax);
sg91.write (ax);
sg92.write (ay);
sg93.write (ay);
delay (000);
Thank you for all the help
