Topic: Possibility of Doing a 2048 point DFT? (Read 569 times) previous topic - next topic
CamJackson
Does anyone have experience doing a 2048 point DFT on an Mega 2560?
Grumpy_Mike
Given you need a float data type for an FFT, that is 4 bytes, then  a 2048 point array will consume all the 8K memory the meg has.
robtillaart
You might extend the RAM of the MEGA with FRAM - https://www.adafruit.com/product/1895
OK, performance will be less than you want but it works, and you can tweak the I2C to at least 600KHz
Check - https://github.com/RobTillaart/Arduino/tree/master/libraries/FRAM
Rob Tillaart
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
(Please do not PM for private consultancy)
CamJackson
What do you think of using a USB card, rather than FRAM due to the cost and memory size differences?
Grumpy_Mike
Not much. I assume you mean USB memory stick, not card. That requires a USB host shield.
While you can use FRAM, you don't need it to be non volatile so simple SRAM will do, something like a 23K256 SPI interfaced chip.
