Topic: Arduino Mega 2560 pin13 LED wont light up (Read 920 times) previous topic - next topic
sheepie
I'm completely new to anything circuit-related. Got the arduino mega 2560, and tried using the blink example from the ide. It was uploaded successfully, but the pin13 LED just wont light up. Any help?
hammy
Are you taking about the on board led or one which you have connected to digital pin 13 ?
sheepie
I'm talking about the onboard LED. The one connecting to pin13 works fine.
sterretje
So you added a led to pin 13? How? Did you use a series resistor?
If you understand an example, use it.
If you don't understand an example, don't use it.
Electronics engineer by trade, software engineer by profession. Trying to get back into electronics after 15 years absence.
sheepie
No... I thought pin 13 has an integrated resistor?
sterretje
Download the schematic and you will see.
sheepie
ieee488
#7
Feb 26, 2018, 11:05 pm Last Edit: Feb 26, 2018, 11:06 pm by ieee488
I am confused.
The yellow LED onboard LED on the Mega is connected to pin 13.
Are you saying that  the green LED indicating +5V isn't lighting.
sterretje
The pin has a resistor.
Pin 13 on the header does not have a resistor between pin and micro controller.
Show a schematic (photo/scan of a hand-drawn one is fine) and post the code that you use.
On an official Mega, it's indirectly connected; there is an opamp that buffers.
bzeebee
So look in device manager. Try another computer. If it doesn't appear in DM, you have a dead board.
digital marketing company in mumbai http://www.bzeebee.in/
ieee488
#10
Feb 27, 2018, 03:40 pm Last Edit: Feb 27, 2018, 03:42 pm by ieee488
I am looking at the schematic here https://www.arduino.cc/en/uploads/Main/arduino-mega2560-schematic.pdf?
I don't see the opamp. Am I looking at the wrong place in the circuit?
I am looking at PWMH connector on the schematic.
ieee488
Thanks.
The OP may be looking at the old one just as I was. Oops.
