Topic: Arduino Due - Clock Chaining  (Read 826 times) previous topic - next topic
parnal
Hello,
Is there anyone who is working or has worked with the Due timer/counter Clock chaining?
I am struggling to find any general information or any code examples to get it working.(any information not mentioned in datasheet would be really appreciated).
Thank you.
ard_newbie
#1
Feb 27, 2018, 03:27 pm Last Edit: Feb 27, 2018, 03:33 pm by ard_newbie
To chain timers, you need to set TC_BMR and TC_CMR accordingly (as stated in the datasheet).
Here is an example sketch with Timer Counter 0 channel 1 clocked by Timer Counter 0 channel 0 TIOA0:
Code: [Select]
/*          TImer Counter 0 channel 1 is chained with Timer Counter 0 channel 0         */
  pinMode(LED_BUILTIN, OUTPUT);
  /*************  Timer Counter 0 Channel 0 to generate PWM pulses thru TIOA0  ************/
  PMC->PMC_PCER0 |= PMC_PCER0_PID27;                      // TC0 power ON - Timer Counter 0 channel 0 IS TC0
  TC0->TC_CHANNEL[0].TC_CMR = TC_CMR_TCCLKS_TIMER_CLOCK4  // MCK/128, clk on rising edge
                              | TC_CMR_WAVE               // Waveform mode
                              | TC_CMR_WAVSEL_UP_RC        // UP mode with automatic trigger on RC Compare
                              | TC_CMR_ACPA_CLEAR          // Clear TIOA0 on RA compare match
                              | TC_CMR_ACPC_SET;           // Set TIOA0 on RC compare match
  TC0->TC_CHANNEL[0].TC_RC = 250;  //<*********************  Frequency = (Mck/128)/TC_RC  Hz = 2625 Hz
  TC0->TC_CHANNEL[0].TC_RA = 100;  //<********************   Duty cycle = (TC_RA/TC_RC) * 100  %
  TC0->TC_CHANNEL[0].TC_CCR = TC_CCR_SWTRG | TC_CCR_CLKEN; // Software trigger TC0 counter and enable
  /*******************     TC1 is internally clocked by TIOA0        ********************/
  PMC->PMC_PCER0 |= PMC_PCER0_PID28;                      // TC1 power ON - Timer Counter 0 channel 1 IS TC1
  TC0->TC_BMR = TC_BMR_TC1XC1S_TIOA0;                     // Timer Counter 0 channel 1 is internally clocked by TIOA0
  TC0->TC_CHANNEL[1].TC_CMR = TC_CMR_TCCLKS_XC1            // External clock XC1 selected
                              | TC_CMR_ACPA_CLEAR          // Clear TIOA1 on RA compare match
                              | TC_CMR_ACPC_SET;           // Set TIOA1 on RC compare match
  TC0->TC_CHANNEL[1].TC_RC = 105;  //<*********************  Frequency = 2625/TC_RC  Hz = 25 Hz
  TC0->TC_CHANNEL[1].TC_RA = 10;  //<********************   Duty cycle = (TC_RA/TC_RC) * 100  %
  TC0->TC_CHANNEL[1].TC_IER = TC_IER_CPCS;                 // Interrupt on RC compare match
  NVIC_EnableIRQ(TC1_IRQn);                                // TC1 Interrupt enable
  TC0->TC_CHANNEL[1].TC_CCR = TC_CCR_SWTRG | TC_CCR_CLKEN; // Software trigger TC1 counter and enable
void TC1_Handler() {
  static uint32_t Count;
  TC0->TC_CHANNEL[1].TC_SR;  // Read and clear status register
  Count++;
  if (Count > 25) {
    digitalWrite(LED_BUILTIN, !digitalRead(LED_BUILTIN));  // Toggle LED every 1 Hz
    Count = 0;
parnal
Thank you ard_newbie its works fine.
TUCTUC77
Hello,
this sketch works very good, but I am trying to output this TIOA1 but I cannot.
Can someone help me to output it ?
Thanks
TUCTUC77
I found the solution myself :
Code: [Select]
void setup_pio_TIOA1 ()  // Configure Ard pin 7 as output TIOA1
  PIOA->PIO_PDR = PIO_PA2A_TIOA1 ;  // disable PIO control
  PIOA->PIO_IDR = PIO_PA2A_TIOA1 ;   // disable PIO interrupts
TUCTUC77
Hello,
do you know if is it possible to chained three timers ?
Because I am trying but it is not working
Thank you
ard_newbie
Is it a Uni assignment ?
Yes it is.
TUCTUC77
