Topic: Can arduino measure mV readings? (Read 830 times) previous topic - next topic
Vicky_96
Hi, I am a newbie. I am interfacing an analog deflection type pH meter with arduino to calibrate the values obtained in mV to a scale of 0-14. How do I get the mV reading in arduino? How to convert the data to digital form and calibrate it?
robtillaart
It is possible to set the analogReference() to internal 1.1Volt and then do measurements. In theory you should get steps of ~1.1 mV  In practice I doubt it will be stable.
You better use an amplifier for that kike below
- https://electronics.stackexchange.com/questions/39303/scale-30-50-mv-signal-to-0-5-v-range
Rob Tillaart
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
(Please do not PM for private consultancy)
