Topic: Help with converting CDJ 1000 SPI SPY project to Arduino  (Read 828 times) previous topic - next topic
needle
Mar 03, 2018, 10:10 pm Last Edit: Mar 03, 2018, 10:20 pm by needle Reason: add attachments
Good evening everyone,
For the last week I've been trying to convert/port this project to the Arduino. It is a little tool to show the data being send back and forth between the Control Pannel and the Mainboard of a CDJ 1000.
This is my first encounter with the SPI protocol. So got a lot to learn here. After contacting the original creator I got a response and he helped me to start but I am stuck now and like to get some help from the Arduino community.
At first I tried the slave example on Nick's SPI site, but I needed something in some sort of silent mode...
After many trial and errors I tried the Logic Analyzer found here. Gladly I saw there was some SPI activity so this must be possible :)
After some more searching and reading I came across this example of an SPI sniffer for a LCD display. This seems to be almost exactly fitting my needs. "to let Arduino work both as slave and as sniffer in silent mode"
So uploaded this code and viola, I got some sort of feedback from the Serial monitor :)
But this is where I'm stuck, I don't understand what is written in the "Reverse_Engineering_Pioneer_CDJ-1000_serial_protocol.pdf"
For example what does "[0-7packages][14 byte][bit0] = PLAY button" translate to? My first goal was to show the pressed buttons in the Serial monitor. But at the moment I just have to understand this first....
Can somebody please explain this to me with an example or a document that I can read so I can continue with this.
thanks for reading so far :)
cheers!
ieee488
ieee488
Looks like the entire message is 8 packages x 27 bytes/package x 8 bits/byte = 1728 bits
Each package is 27 bytes.
The entire document describes what each bit of those 1728 bits are.
needle
Oh now I think I get it...  :-[
needle
Flowmatic
Hello
Would it be easy to write a small program for arduino that sends the spi commands just for the Basic things Like Play,cue ?
The guy who did the spi-spy for cdj has build a rekordbox player for cdj1000 to and with a arduino with some encoders and Buttons sending These commands to his rekordbox player (its a 32f746g with firmware he wrote) a nice standalone dj mediaplayer could be build without the need of a cdj1000mk3.
bdomi40
Hello,
I am also interested in this project.
I invite you to look at here https://www.vandoeselaar.com/tinkering/cdj-1000-mk3-for-rekordbox/
And here : https://www.youtube.com/watch?v=3B1zZD2IAlU
bdomi40
This post describes how the SPI interface works :
http://www.gammon.com.au/spi
