Topic: Escape Room riddles and Arduino (Read 225 times) previous topic - next topic
elginian
Mar 08, 2018, 10:09 pm Last Edit: Mar 08, 2018, 10:22 pm by elginian
Hi everyone,
I am building escape rooms and is currently planning to make riddles for them. I am making decisions on what type of technology to use to make riddles. Considering that the riddles will be run 8-12 hours a day. Should I use microcontrollers/Arduino or pure circuit to make the riddles?
I understand that Arduino will be necessary for complex riddles. But in general, assuming the setup is correct, is Arduino durable in this case?
allanhurst
If continuously powered an arduino will run indefinitely - many years.
Allan
elginian
Allan
Hi Allan, thanks for the answer. To clarify, when you talk about continuously powered, do you mean I should reduce the times where I power on/off the device?
DrAzzy
No, you may connect or remove power as much as you want
ATtiny core for 841+1634+828 and x313/x4/x5/x61/x7/x8 series Board Manager:
http://drazzy.com/package_drazzy.com_index.json
ATtiny breakouts (some assembled), mosfets and awesome prototyping board in my store http://tindie.com/stores/DrAzzy
INTP
Power it from the wall (simple USB phone charger would work just fine) and it'll run indefinitely. It will fail if your code is bad or if the wall loses power.
allanhurst
#5
Mar 09, 2018, 03:21 am Last Edit: Mar 09, 2018, 03:30 am by allanhurst
To clarify.
The code you program into an  arduino is retained even when the power is removed. It's held in 'non-volatile' memory - like the bios in your PC.
On restart it will run again.
An indefinite number of times.
Millions? Probably.
Allan
