Topic: Arduino plus few RFID (Read 105 times) previous topic - next topic
Wowas
it is possible to connect few RFID readers to one Arduino?
I have Arduino Uno and RFID RC522, but I can buy something else if my components are not the best to do this.
johnwasser
The RFID RC522 uses the SPI interface.  All units will share the MOSI, MISO, and SCK pins but will each need their own SS and RST digital output pins.  Assuming the only other device you need is Serial you can fit seven RFID readers on an Arduino UNO.  You'll even have one pin to spare.  For example, one possible pin layout is:
13, 12, 11: Hardware SPI
10, 9: RFID 1  (10 is the hardware SS pin and must be an OUTPUT)
8, 7: RFID 2
6, 5: RFID 3
4, 3: RFID 4
1, 0: Serial
A0, A1: RFID 5
A2, A3: RFID 6
A4, A5: RFID 7
Send Bitcoin tips to: 1G2qoGwMRXx8az71DVP1E81jShxtbSh5Hp
Wowas
Thanks! I will check it today. So I need to for example connect together MOSI from RFID1 with MOSI from RFID2 and then connect it to MOSI on Arduino?
johnwasser
Yes.  All of the slave devices use MOSI (Master Out/Slave In) to receive data from the Arduino and MISO (Master In/Slave Out) to send data to the Arduino.  They each have a separate SS (Slave Select) pin and only the slave whose SS pin is LOW talks to the Arduino.  The SCLK (Serial Clock) output provides signal clocking for whichever slave is selected.
