Topic: LCD clear (Read 1 time) previous topic - next topic
ted
Mar 09, 2018, 03:20 am Last Edit: Mar 09, 2018, 05:53 am by ted
How to implement the function -   lcd.clear(); activated by push button ?
 buttonState = digitalRead(buttonPin); //sample the state of the button - is it pressed or not?
 if( (buttonState == LOW);  // do LCD clear ?
 lcd.clear();
// EmonLibrary examples openenergymonitor.org, Licence GNU GPL V3
#include "EmonLib.h"             // Include Emon Library
#include <LiquidCrystal.h>
LiquidCrystal lcd(PA0, PA1, PA2, PA3, PA4, PA5);
EnergyMonitor emon1;
float  cur, acur[50], sumc;
const int buttonPin = PB4;
  digitalWrite(buttonPin, HIGH);
  pinMode(PB4, INPUT_PULLUP);// button pin
  pinMode(PA7, INPUT);    // I2
  lcd.begin(16, 2);
  emon1.current(PA7, 2500);
  emon1.calcVI(20, 2000);
  emon1.serialprint();
  float Irms = emon1.Irms;
  lcd.setCursor(0, 1);
  lcd.print("U=");
  lcd.print(Irms);
  lcd.setCursor(0, 0);
 lcd.print("H=");
  lcd.print(Irms );    // Value to be cleared when button is pressed
marco_c
A pushbutton is activated when it transitions from the off state (LOW OR HIGH, depends how the switch is wired) to the on state (HIGH or LOW). You need to remember what it was last time you checked and what it is now.
Mechanical switches also suffer from bounce, which will trigger the signal to go on and off a few times before it settles into the final state. There are lots of examples about eliminating bounce using either hardware or software methods.
Arduino Libraries https://github.com/MajicDesigns?tab=Repositories
Parola for Arduino https://github.com/MajicDesigns/Parola
ted
Compiling error
Arduino: 1.8.3 (Windows Vista), Board: "Generic STM32F103C series, STM32F103C8 (20k
AC_meter_2LCD_b:24: error: expected initializer before 'void'
C:\Users\OWNER\Desktop\bibloteka\AC_meter_2LCD_b\AC_meter_2LCD_b.ino: In function 'void loop()':
AC_meter_2LCD_b:28: error: expected primary-expression before 'if'
     if( ( (buttonState == LOW);
AC_meter_2LCD_b:28: error: expected ')' before 'if'
AC_meter_2LCD_b:29: error: expected primary-expression before ')' token
AC_meter_2LCD_b:29: error: expected ';' before ')' token
AC_meter_2LCD_b:43: error: expected unqualified-id before '(' token
 lcd.(Irms); // ?
Multiple libraries were found for "LiquidCrystal.h"
 Used: C:\Users\OWNER\AppData\Local\Arduino15\packages\stm32duino\hardware\STM32F1\2018.1.3\libraries\LiquidCrystal
 Not used: C:\Users\OWNER\Documents\Arduino\libraries\Newliquidcrystal_1.3.5
 Not used: C:\Users\OWNER\Desktop\183\arduino-1.8.3\libraries\LiquidCrystal
Using library EmonLib at version 1.1.0 in folder: C:\Users\OWNER\Documents\Arduino\libraries\EmonLib
Using library LiquidCrystal in folder: C:\Users\OWNER\AppData\Local\Arduino15\packages\stm32duino\hardware\STM32F1\2018.1.3\libraries\LiquidCrystal (legacy)
exit status 1
 int buttonState; // = digitalRead(buttonPin);
int H
  lcd.begin(16, 2);
    if (buttonState == LOW);
        // lcd.(Irms); // ?
lcd.print("U=");
lcd.print(Irms);
lcd.(Irms); // ?
lcd.print("H=");
lcd.print(Irms );
ted
Thanks
Please look at last line of the code
TKall
int H
vaj4088
Well, for starters, this line
int H
is missing a semicolon, and
does not do anything, and
lcd.(Irms); // ?
is just plain wrong and I don't know what was intended.
ted
Thanks
I made correction and new error is;
AC_meter_2LCD_b:31: error: 'Irms' was not declared in this scope
     lcd.clear(Irms);
AC_meter_2LCD_b:44: error: expected unqualified-id before '(' token
   lcd.(Irms); // ?
exit status 1
int H;
  lcd.begin(16, 2);
lcd.clear(Irms);
  lcd.print("U=");
  lcd.print(Irms);
  lcd.(Irms); // ?
  lcd.print("H=");
  lcd.print(Irms );
TKall
ted
When button is pressed "Irms " value should be cleared
TKall
You were already told that this. if (buttonState == LOW);
Does nothing
ted
should do next line below - lcd.clear(Irms); or  clear(Irms); ?
marco_c
Your last line has no meaning to me.
cheche_romo
then shouldn't it be:
  // When button state is low
  lcd.clear();
  // When button state is high
PaulMurrayCbr
When I see someone mangling the syntax of the language this badly, I usually suggest that they google "C++ tutorial" and do a C++ tutorial. You can't fix this kind of thing by fixing each error. You'll wind up with something that compiles but that does not do what you want.
http://paulmurraycbr.github.io/ArduinoTheOOWay.html
ted
#14
Mar 09, 2018, 03:06 pm Last Edit: Mar 09, 2018, 03:07 pm by ted
Thanks romo
I have no errors, now I will try to work on functionality of the program.
int (clear);
int (Irms);
int H;
  lcd.begin(16, 2);
    lcd.clear();
  lcd.print("U=");
  lcd.print(Irms);
  lcd.print("H=");
  lcd.print(Irms );
