Topic: avrdude not in sync error with new Arduino IDE, but works with 1.6.4 (Read 1 time) previous topic - next topic
BlakeCarmichael
I am using multiple different Arduino Nanos and recently have run into issues with uploading my code. I updated to the newest version of Arduino and that didn't work. The error code I am getting from Arduino 1.8.5 is shown below. The IDE works fine for uploading to an Arduino Uno.
For the Nanos that are not uploading properly, if I switch to Arduino 1.6.4 the upload goes fine. I've also posted the verbose output for that below.
One thing I notice that is different, is the "Overriding Baud Rate" for the 1.6.4 upload is 57600, whereas for the 1.8.5 upload it is 115200.
Does this have anything to do with it?
Thanks,
Blake
1.8.5:
         System wide configuration file is "C:\Users\Blake\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino9/etc/avrdude.conf"
         Using Port                    : COM7
         Using Programmer              : arduino
         Overriding Baud Rate          : 115200
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x83
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x83
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x83
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x83
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x83
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x83
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x83
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x83
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x83
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x83
avrdude done.  Thank you.
1.6.4:
         System wide configuration file is "C:\Program Files (x86)\arduino-1.6.4\hardware\tools\avr/etc/avrdude.conf"
         Using Port                    : COM7
         Overriding Baud Rate          : 57600
         AVR Part                      : ATmega328P
         Chip Erase delay              : 9000 us
         PAGEL                         : PD7
         BS2                           : PC2
         RESET disposition             : dedicated
         RETRY pulse                   : SCK
         serial program mode           : yes
         parallel program mode         : yes
         Timeout                       : 200
         StabDelay                     : 100
         CmdexeDelay                   : 25
         SyncLoops                     : 32
         ByteDelay                     : 0
         PollIndex                     : 3
         PollValue                     : 0x53
         Memory Detail                 :
                                  Block Poll               Page                       Polled
           Memory Type Mode Delay Size  Indx Paged  Size   Size #Pages MinW  MaxW   ReadBack
           eeprom        65    20     4    0 no       1024    4      0  3600  3600 0xff 0xff
           flash         65     6   128    0 yes     32768  128    256  4500  4500 0xff 0xff
           lfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           hfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           efuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           lock           0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           calibration    0     0     0    0 no          1    0      0     0     0 0x00 0x00
           signature      0     0     0    0 no          3    0      0     0     0 0x00 0x00
         Programmer Type : Arduino
         Description     : Arduino
         Hardware Version: 2
         Firmware Version: 1.16
         Vtarget         : 0.0 V
         Varef           : 0.0 V
         Oscillator      : Off
         SCK period      : 0.1 us
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.00s
avrdude: Device signature = 0x1e950f
avrdude: reading input file "C:\Users\Blake\AppData\Local\Temp\build739471601181305352.tmp/hallsensor.cpp.hex"
avrdude: writing flash (4558 bytes):
Writing | ################################################## | 100% 1.28s
avrdude: 4558 bytes of flash written
avrdude: verifying flash memory against C:\Users\Blake\AppData\Local\Temp\build739471601181305352.tmp/hallsensor.cpp.hex:
westfw
In the "Tools" menu, set the Processor to "ATmega328 (Old Bootloader)"
BlakeCarmichael
That worked. Thank you.
...I feel terrible about spending hours looking for that solution
