Today I started using my (through-hole) Uno on Linux and discovered serial communications didn't work reliably. After some searching I discovered this is a known problem with older 8u2 firmware and an update should fix the problems.
Attempting the procedure described at
http://arduino.cc/en/Hacking/DFUProgramming8U2 has not been successful. I initially attempted to follow the procedure on Windows. I held a connection between the HWB and ground on the back, connected the reset and ground pads on the front, released the reset connection, then released the HWB connection.
The Uno then enumerates under the device manager as Atmel USB Devices|AT90USB82, which I presume is proper. Using Flip (3.4.2) at this point, selecting the Atmega8U2 device and then connection type USB, a dialog titled "USB Port Connection" emerges. Selecting "Open" on that dialog then fails with "Could not open USB Device."
Most of the discussion is oriented around using dfu-programmer under Linux so I then connected my Uno to a Linux machine and tried the procedure again. The first step of the procedure fails in a similar way:
$ sudo dfu-programmer at90usb82 erase
dfu-programmer: no device present.
lsusb appears indicate the device is properly in DFU mode from what I have gathered:
~$ lsusb
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 005 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 004 Device 012: ID 03eb:2ff7 Atmel Corp.
Bus 004 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 003 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 002 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
with -v output:
$ sudo lsusb -vs4:12
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 1.10
bDeviceClass 0 (Defined at Interface level)
bDeviceSubClass 0
bDeviceProtocol 0
bMaxPacketSize0 32
idVendor 0x03eb Atmel Corp.
idProduct 0x2ff7
bcdDevice 0.00
iManufacturer 0
iProduct 1 Arduino Uno DFU
iSerial 0
bNumConfigurations 1
Configuration Descriptor:
bLength 9
bDescriptorType 2
wTotalLength 27
bNumInterfaces 1
bConfigurationValue 1
iConfiguration 0
bmAttributes 0x80
(Bus Powered)
MaxPower 100mA
Interface Descriptor:
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 0
bInterfaceClass 254 Application Specific Interface
bInterfaceSubClass 1 Device Firmware Update
bInterfaceProtocol 2
iInterface 0
** UNRECOGNIZED: 09 21 03 00 00 00 0c 00 01
cannot read device status, Broken pipe (32)
(I don't know if the broken pipe error at the end of the lsusb -v output indicates something amiss or not.)
In desperation I also tried the method with soldering a 10k resistor between the HWB and ground and all the results are the same.
