Topic: [solved] Lilypad SD Card Breakout (Read 603 times) previous topic - next topic
augustine1415
Mar 13, 2018, 03:52 am Last Edit: Mar 13, 2018, 05:55 pm by augustine1415
I am trying to connect the micro SD breakout board from Sparkfun to the Lilypad Arduino and want to use the programming header pins instead of the regular D I/O pins.  I have connected these pins to the corresponding ones on the breakout board and connected the CS to pin 10. Using the SDfat library I get the error code 0x20 0x00. I am not sure why this doesn't run. I have formatted the SD card using the SD Formatter as well.
Update: used wrong pins
