Topic: robotics (Read 558 times) previous topic - next topic
NEELISAMPATH
i want to connect RPM Tracking sensor(input) to the board and using this data(input ) operate the two solenoids with in the time  0- 25 milliseconds which ARDUINO BOARD is suitable for my project.
RPM =3000 to 6000
solenoid type = DC
Voltage =12 v
soleniods speed =0 to 25 milliseconds
PaulS
Quote
Specifically, what sensor?
Quote
What two solenoids?
Quote
What does that mean? Read the RPM, and then randomly pick a time in that range, activate the solenoid for that amount of time, and then turn it off?
Quote
Any of the blue ones.
vinceherman
Since I can't buy you a beer, we have to settle for Karma++
NEELISAMPATH
#3
Mar 14, 2018, 03:22 pm Last Edit: Mar 14, 2018, 03:54 pm by NEELISAMPATH Reason: more accurate information
1Q:Specifically, what sensor?
A: Engine speed(rpm) tracking sensor
2Q :What two solenoids?
A: push and pull type (Linear motion ) solenoids
3Q: What does that mean? Read the RPM, and then randomly pick a time in that range, activate the solenoid for that amount of time, and then turn it off?
A: yes you are right
4Q:Any of the blue ones.
A: Iam cannot understand this statement
5Q:can add these two atduino boards?
(Arduino Uno REV3 [Original - Made in Italy] ATmega328P) and
(New 2A H-Bridge 2 way DC Motor Driver Module L298P Shield For Arduino)
vinceherman
@NEELISAMPATH,
Do you have links to the datasheets for your sensor and solenoids?
Or have you not decided yet which you will get?
Quote
This was a humorous way of saying that any arduino will work for this task.
NEELISAMPATH
@NEELISAMPATH,
i dont have data sheet
 yes
TomGeorge
OPs two images,
Tom.. :)
Everything runs on smoke, let the smoke out, it stops running....
TomGeorge
What we need are;
  • Data/specs for the sensor.
  • Data/specs for the solenoids.
What is the application?
What are you trying to accomplish?
Tom... :)
NEELISAMPATH
What we need are;
Requirements of solenoids
1) Voltage                   - 12 v
2) Stroke                     - 80 to 100 mm (pull and push type)
3) Force                      - 700N (operate the 125 cc bike engine valve)
4) Duty cycle               - 30 to 35 mins
5) Response speed**  - 0 to 25 milliseconds
6) Type                       - DC
7) Quantity                 -  2
8) Structure                - Tubular
** Stroke complete in 0 to 25 milliseconds
sensor requirements
"Segolike Car Engine Crankshaft Position Sensor for VW Passat B5 Bora OEM 0261210165"
1)hall type sensor
2)RPM-5000
