// variables that can be changed
const int S = 98; //distance between center of left and right sensors in millimeters
const int resultDelay = 5000; // time display of measurement results in milliseconds
const int animationDelay = 50; // direction ticker delay time in milliseconds
const unsigned long timeoutDelay = 160000; // the waiting time of the second sensor signal in milliseconds
const int decimals = 2; // the accuracy of the result display
// arrays, which can added or changed
const String scale[][2] = {{" HO", "87"}, {" TT", "120"}, {" N", "160"}}; // array of scales (display on-screen, the multiplier)
const String units[][2] = {{"KPH", "3.6"}, {"MPH", "2.23694"}}; // units array (display on-screen, conversion factor from meter per second)
// Creates a Bounce object, which you will later assign to an input pin.
Bounce scaleBouncer = Bounce();
Bounce unitsBouncer = Bounce();
LiquidCrystal lcd(2, 3, 4, 5, 6, 7); // (RS, E, DB4, DB5, DB6, DB7) initialize the library with the numbers
PLEASE CAN YOU TELL ME WHAT THIS MEANS IN TO THE CODE.
IT MAKES THE UPLOADING STOP
THIS IS ONLY THE FRONT PART OF THE CODE
CODE WILL NOT LOAD ONTO A ARDUINO, CAN SOMEONE HELP PLEASE.
KIND REGARDS
