Topic: [SOLVED] Problem with camera module OV7670 (Read 17021 times) previous topic - next topic
juma_yetu
Kudos to metanbright for taking the trouble to document this in the spirit of helping others.
falexandru
EmDG
Hello, Thanks for this guide. I've been able to get the camera to work. However, i get scrambled images. I've added the "initializeCamera()" code but it doesn't fix the problem. How do i resolve this? Thanks.
Omany
If you can't get a good image from the camera, you can try to set its registers to common values.
Put this method in the sketch and call it at the end of the "setup" function.
Code: [Select]
void initializeCamera() {
  // these are common registers values for initializing the camera to QVGA (320 x 240) mode at the maximum clock prescaler:
  writeCameraRegister(0x12, 0x80); // reset all camera registers to default value
  delay(1000); // wait for reset proccess to be done (because it is quite slow)
  writeCameraRegister(0x3A, 0x04);
  writeCameraRegister(0x12, 0x00);
  writeCameraRegister(0x17, 0x13);
  writeCameraRegister(0x18, 0x01);
  writeCameraRegister(0x32, 0xB6);
  writeCameraRegister(0x19, 0x02);
  writeCameraRegister(0x1A, 0x7A);
  writeCameraRegister(0x03, 0x0A);
  writeCameraRegister(0x0C, 0x00);
  writeCameraRegister(0x3E, 0x00);
  writeCameraRegister(0x70, 0x3A);
  writeCameraRegister(0x71, 0x35);
  writeCameraRegister(0x72, 0x11);
  writeCameraRegister(0x73, 0xF0);
  writeCameraRegister(0xA2, 0x01);
  writeCameraRegister(0x15, 0x00);
  writeCameraRegister(0x7A, 0x20);
  writeCameraRegister(0x7B, 0x10);
  writeCameraRegister(0x7C, 0x1E);
  writeCameraRegister(0x7D, 0x35);
  writeCameraRegister(0x7E, 0x5A);
  writeCameraRegister(0x7F, 0x69);
  writeCameraRegister(0x80, 0x76);
  writeCameraRegister(0x81, 0x80);
  writeCameraRegister(0x82, 0x88);
  writeCameraRegister(0x83, 0x8F);
  writeCameraRegister(0x84, 0x96);
  writeCameraRegister(0x85, 0xA3);
  writeCameraRegister(0x86, 0xAF);
  writeCameraRegister(0x87, 0xC4);
  writeCameraRegister(0x88, 0xD7);
  writeCameraRegister(0x89, 0xE8);
  writeCameraRegister(0x13, 0xC0);
  writeCameraRegister(0x00, 0x00);
  writeCameraRegister(0x10, 0x00);
  writeCameraRegister(0x0D, 0x40);
  writeCameraRegister(0x14, 0x18);
  writeCameraRegister(0xA5, 0x05);
  writeCameraRegister(0xAB, 0x07);
  writeCameraRegister(0x24, 0x95);
  writeCameraRegister(0x25, 0x33);
  writeCameraRegister(0x26, 0xE3);
  writeCameraRegister(0x9F, 0x78);
  writeCameraRegister(0xA0, 0x68);
  writeCameraRegister(0xA1, 0x03);
  writeCameraRegister(0xA6, 0xD8);
  writeCameraRegister(0xA7, 0xD8);
  writeCameraRegister(0xA8, 0xF0);
  writeCameraRegister(0xA9, 0x90);
  writeCameraRegister(0xAA, 0x94);
  writeCameraRegister(0x13, 0xC5);
  writeCameraRegister(0x30, 0x00);
  writeCameraRegister(0x31, 0x00);
  writeCameraRegister(0x0E, 0x61);
  writeCameraRegister(0x0F, 0x4B);
  writeCameraRegister(0x16, 0x02);
  writeCameraRegister(0x1E, 0x07);
  writeCameraRegister(0x21, 0x02);
  writeCameraRegister(0x22, 0x91);
  writeCameraRegister(0x29, 0x07);
  writeCameraRegister(0x33, 0x0B);
  writeCameraRegister(0x35, 0x0B);
  writeCameraRegister(0x37, 0x1D);
  writeCameraRegister(0x38, 0x71);
  writeCameraRegister(0x39, 0x2A);
  writeCameraRegister(0x3C, 0x78);
  writeCameraRegister(0x4D, 0x40);
  writeCameraRegister(0x4E, 0x20);
  writeCameraRegister(0x69, 0x00);
  writeCameraRegister(0x74, 0x10);
  writeCameraRegister(0x8D, 0x4F);
  writeCameraRegister(0x8E, 0x00);
  writeCameraRegister(0x8F, 0x00);
  writeCameraRegister(0x90, 0x00);
  writeCameraRegister(0x91, 0x00);
  writeCameraRegister(0x96, 0x00);
  writeCameraRegister(0x9A, 0x00);
  writeCameraRegister(0xB0, 0x84);
  writeCameraRegister(0xB1, 0x0C);
  writeCameraRegister(0xB2, 0x0E);
  writeCameraRegister(0xB3, 0x82);
  writeCameraRegister(0xB8, 0x0A);
  writeCameraRegister(0x43, 0x0A);
  writeCameraRegister(0x44, 0xF0);
  writeCameraRegister(0x45, 0x34);
  writeCameraRegister(0x46, 0x58);
  writeCameraRegister(0x47, 0x28);
  writeCameraRegister(0x48, 0x3A);
  writeCameraRegister(0x59, 0x88);
  writeCameraRegister(0x5A, 0x88);
  writeCameraRegister(0x5B, 0x44);
  writeCameraRegister(0x5C, 0x67);
  writeCameraRegister(0x5D, 0x49);
  writeCameraRegister(0x5E, 0x0E);
  writeCameraRegister(0x6C, 0x0A);
  writeCameraRegister(0x6D, 0x55);
  writeCameraRegister(0x6E, 0x11);
  writeCameraRegister(0x6F, 0x9E);
  writeCameraRegister(0x6A, 0x40);
  writeCameraRegister(0x01, 0x40);
  writeCameraRegister(0x02, 0x60);
  writeCameraRegister(0x13, 0xC7);
  writeCameraRegister(0x4F, 0x80);
  writeCameraRegister(0x50, 0x80);
  writeCameraRegister(0x51, 0x00);
  writeCameraRegister(0x52, 0x22);
  writeCameraRegister(0x53, 0x5E);
  writeCameraRegister(0x54, 0x80);
  writeCameraRegister(0x58, 0x9E);
  writeCameraRegister(0x41, 0x08);
  writeCameraRegister(0x3F, 0x00);
  writeCameraRegister(0x75, 0x05);
  writeCameraRegister(0x76, 0xE1);
  writeCameraRegister(0x4C, 0x00);
  writeCameraRegister(0x77, 0x01);
  writeCameraRegister(0x3D, 0x48);
  writeCameraRegister(0x4B, 0x09);
  writeCameraRegister(0xC9, 0x60);
  writeCameraRegister(0x56, 0x40);
  writeCameraRegister(0x34, 0x11);
  writeCameraRegister(0x3B, 0x12);
  writeCameraRegister(0xA4, 0x82);
  writeCameraRegister(0x97, 0x30);
  writeCameraRegister(0x98, 0x20);
  writeCameraRegister(0x99, 0x30);
  writeCameraRegister(0x9A, 0x84);
  writeCameraRegister(0x9B, 0x29);
  writeCameraRegister(0x9C, 0x03);
  writeCameraRegister(0x9D, 0x4C);
  writeCameraRegister(0x9E, 0x3F);
  writeCameraRegister(0x78, 0x04);
  writeCameraRegister(0x79, 0x01);
  writeCameraRegister(0xC8, 0xF0);
  writeCameraRegister(0x79, 0x0F);
  writeCameraRegister(0xC8, 0x00);
  writeCameraRegister(0x79, 0x10);
  writeCameraRegister(0xC8, 0x7E);
  writeCameraRegister(0x79, 0x0A);
  writeCameraRegister(0xC8, 0x80);
  writeCameraRegister(0x79, 0x0B);
  writeCameraRegister(0xC8, 0x01);
  writeCameraRegister(0x79, 0x0C);
  writeCameraRegister(0xC8, 0x0F);
  writeCameraRegister(0x79, 0x0D);
  writeCameraRegister(0xC8, 0x20);
  writeCameraRegister(0x79, 0x09);
  writeCameraRegister(0x79, 0x02);
  writeCameraRegister(0xC8, 0xC0);
  writeCameraRegister(0x79, 0x03);
  writeCameraRegister(0xC8, 0x40);
  writeCameraRegister(0x79, 0x05);
  writeCameraRegister(0xC8, 0x30);
  writeCameraRegister(0x79, 0x26);
  writeCameraRegister(0xFF, 0xFF);
  writeCameraRegister(0x15, 0x20);
  writeCameraRegister(0x0C, 0x04);
  writeCameraRegister(0x3E, 0x19);
  writeCameraRegister(0x73, 0xF1);
  writeCameraRegister(0x17, 0x16);
  writeCameraRegister(0x18, 0x04);
  writeCameraRegister(0x32, 0xA4);
  writeCameraRegister(0x8C, 0x00);
  writeCameraRegister(0x04, 0x00);
  writeCameraRegister(0x40, 0xC0);
  writeCameraRegister(0x14, 0x6A);
  writeCameraRegister(0x3D, 0x40);
  writeCameraRegister(0x11, 0x1F);
  writeCameraRegister(0x0C, 0x08);
  writeCameraRegister(0x12, 0x10);
  delay(1000); // wait for registers to be set (because it is quite slow)
i try this but get this can u tell me how to fixed
WI_DED
Hi, please can you help me ?
i followed what you already done but nothing's happened and i can't know where i will found the pic if it is functional
jlsilicon
#20
Oct 04, 2018, 07:50 pm Last Edit: Oct 04, 2018, 07:56 pm by jlsilicon
Omany,
I had related problems myself.
If you look at your image closely, it looks like that there is some image definition mixed in there.
It could be that you have misaligned your Image by Size or Bytes.
The Final Image Format probably does not match your Camera Bytes per Pixel / Line.
bikram05
hello @matanbright.great job. but i have a confusion  in the part of seeing the image " For receiving images you will need to install the software from one of the tutorials from the first post"...please help me with this stuff..:)
thank you
zoomx
The image is transmitted over serial so you have to use a program in a PC to see it.
RizN81
#23
Feb 26, 2019, 05:08 pm Last Edit: Feb 26, 2019, 05:11 pm by RizN81
Hi matanbright,
I just brought OV7670 without FIFO and Arduino Mega and as per your documentation i tried it but unfortunately i am not getting exact images :smiley-confuse: . Check at GDrive.
 I have done same connection for Mega and also using your sketch but its not working. I am doing this for my college project.
Will you please help me???
CIMLAB
Hi matanbright,
Thank you for the code you uploaded. I am just trying to get it to work, but I had the following questions:
1- The arduino outputs the 8MHz clock with a peak to peak voltage of 5V, I believe this isn't good for the sensor,are the two 4.7k resistors you included in between the arduino and the external clock supposed to reduce this to 3.3V?
2- When I run your code, even though I've put a 1MHz baud rate on my terminal, I am receiving weird values such as backwards questions marks. Have you had this problem before? If so, do you have any suggested solutions?
Thanks,
Kasra
abrar408
i am trying to get the image data pixel by pixel from ov7670 to serial monitor and to store it into arduino memory which i can access later. i am using arduino mega and the camera is configured to 160x120 resolution. Any suggestions or code from which i can get help from?
ilylily07
hye i also buy the same camera module as yours.im using your code and circuit connection but in cmd it stated that the image is not found.please help me.
// Pins configurations:
// SDA/SIOD ---> pin A4 (for Arduino UNO) | pin 20/SDA (for Arduino MEGA)
// SCL/SIOC ---> pin A5 (for Arduino UNO) | pin 21/SCL (for Arduino MEGA)
// MCLK/XCLK --> pin 11 (for Arduino UNO) | pin 10 (for Arduino MEGA)
// PCLK -------> pin 2
// VS/VSYNC ---> pin 3
// HS/HREF ----> pin 8
// D0 ---------> pin A0
// D1 ---------> pin A1
// D2 ---------> pin A2
// D3 ---------> pin A3
// D4 ---------> pin 4
// D5 ---------> pin 5
// D6 ---------> pin 6
// D7 ---------> pin 7
#include <Wire.h>
#define CAMERA_ADDRESS 0x21
// Definitions of functions for manipulating the Arduino boards pins according to each Arduino board registers, so the code will work for both Arduino UNO and Arduino MEGA:
// The only change is the connections of the SDA/SIOD, SCL/SIOC and MCLK/XCLK pins to each board (see the pins configurations above).
#if defined(__AVR_ATmega1280__) || defined(__AVR_ATmega2560__) // If you are using Arduino MEGA the IDE will automatically define the "__AVR_ATmega1280__" or "__AVR_ATmega2560__" constants.
#define TIMER2_PWM_A_PIN_MODE_OUTPUT() ({ DDRB |= 0b00010000; })
#define PIN2_DIGITAL_READ() ({ (PINE & 0b00010000) == 0 ? LOW : HIGH; })
#define PIN3_DIGITAL_READ() ({ (PINE & 0b00100000) == 0 ? LOW : HIGH; })
#define PIN4_DIGITAL_READ() ({ (PING & 0b00100000) == 0 ? LOW : HIGH; })
#define PIN5_DIGITAL_READ() ({ (PINE & 0b00001000) == 0 ? LOW : HIGH; })
#define PIN6_DIGITAL_READ() ({ (PINH & 0b00001000) == 0 ? LOW : HIGH; })
#define PIN7_DIGITAL_READ() ({ (PINH & 0b00010000) == 0 ? LOW : HIGH; })
#define PIN8_DIGITAL_READ() ({ (PINH & 0b00100000) == 0 ? LOW : HIGH; })
#define PINA0_DIGITAL_READ() ({ (PINF & 0b00000001) == 0 ? LOW : HIGH; })
#define PINA1_DIGITAL_READ() ({ (PINF & 0b00000010) == 0 ? LOW : HIGH; })
#define PINA2_DIGITAL_READ() ({ (PINF & 0b00000100) == 0 ? LOW : HIGH; })
#define PINA3_DIGITAL_READ() ({ (PINF & 0b00001000) == 0 ? LOW : HIGH; })
#elif defined(__AVR_ATmega328P__) // If you are using Arduino UNO the IDE will automatically define the "__AVR_ATmega328P__" constant.
#define TIMER2_PWM_A_PIN_MODE_OUTPUT() ({ DDRB |= 0b00001000; })
#define PIN2_DIGITAL_READ() ({ (PIND & 0b00000100) == 0 ? LOW : HIGH; })
#define PIN3_DIGITAL_READ() ({ (PIND & 0b00001000) == 0 ? LOW : HIGH; })
#define PIN4_DIGITAL_READ() ({ (PIND & 0b00010000) == 0 ? LOW : HIGH; })
#define PIN5_DIGITAL_READ() ({ (PIND & 0b00100000) == 0 ? LOW : HIGH; })
#define PIN6_DIGITAL_READ() ({ (PIND & 0b01000000) == 0 ? LOW : HIGH; })
#define PIN7_DIGITAL_READ() ({ (PIND & 0b10000000) == 0 ? LOW : HIGH; })
#define PIN8_DIGITAL_READ() ({ (PINB & 0b00000001) == 0 ? LOW : HIGH; })
#define PINA0_DIGITAL_READ() ({ (PINC & 0b00000001) == 0 ? LOW : HIGH; })
#define PINA1_DIGITAL_READ() ({ (PINC & 0b00000010) == 0 ? LOW : HIGH; })
#define PINA2_DIGITAL_READ() ({ (PINC & 0b00000100) == 0 ? LOW : HIGH; })
#define PINA3_DIGITAL_READ() ({ (PINC & 0b00001000) == 0 ? LOW : HIGH; })
#endif
void initializePWMTimer() {
  cli();
  TIMER2_PWM_A_PIN_MODE_OUTPUT(); // Set the A PWM pin of TIMER2 to output
  ASSR &= ~(_BV(EXCLK) | _BV(AS2));
  TCCR2A = (1 << COM2A0) | (1 << WGM21) | (1 << WGM20);
  TCCR2B = (1 << WGM22) | (1 << CS20);
  OCR2A = 0;
  sei();
byte readCameraRegister(byte registerId) {
  Wire.beginTransmission(CAMERA_ADDRESS);
  Wire.write(registerId);
  Wire.endTransmission();
  Wire.requestFrom(CAMERA_ADDRESS, 1);
  while (Wire.available() <= 0);
  byte registerValue = Wire.read();
  delay(1);
  return registerValue;
void writeCameraRegister(byte registerId, byte registerValue) {
  Wire.write(registerValue);
  delay(1);
void captureFrame(unsigned int frameWidth, unsigned int frameHeight) {
  Serial.print("*RDY*"); // send to the frame capture software a "start of frame" message for beginning capturing
  cli(); // disable all interrupts during frame capture (because it needs to be as fast as possible)
  while (PIN3_DIGITAL_READ() == LOW); // wait until VS/VSYNC pin is high
  while (PIN3_DIGITAL_READ() == HIGH); // wait until VS/VSYNC pin is low
  unsigned int tempWidth = 0;
  while (frameHeight--) {
    tempWidth = frameWidth;
    while (tempWidth--) {
      while (PIN2_DIGITAL_READ() == LOW); // wait until PCLK pin is high
      while (PIN2_DIGITAL_READ() == HIGH); // wait until PCLK pin is low
      byte byteToWrite = 0b00000000;
      byteToWrite |= ((PIN7_DIGITAL_READ() == HIGH) << 7);
      byteToWrite |= ((PIN6_DIGITAL_READ() == HIGH) << 6);
      byteToWrite |= ((PIN5_DIGITAL_READ() == HIGH) << 5);
      byteToWrite |= ((PIN4_DIGITAL_READ() == HIGH) << 4);
      byteToWrite |= ((PINA3_DIGITAL_READ() == HIGH) << 3);
      byteToWrite |= ((PINA2_DIGITAL_READ() == HIGH) << 2);
      byteToWrite |= ((PINA1_DIGITAL_READ() == HIGH) << 1);
      byteToWrite |= ((PINA0_DIGITAL_READ() == HIGH));
      UDR0 = byteToWrite; // send data via serial connection with UART register (we need to use the serial register directly for fast transfer)
      // ignore each second byte (for a grayscale image we only need each first byte, which represents luminescence)
  sei(); // enable all interrupts
  initializePWMTimer();
  Wire.begin();
  Serial.begin(1000000); // the frame capture software communicates with the Arduino at a baud rate of 1MHz
  captureFrame(320, 240); // capture a frame at QVGA resolution (320 x 240)
ilylily07
thank you
you will need to install java jdk and follow the steps
srishtiasrn
#28
Feb 08, 2020, 11:19 am Last Edit: Feb 08, 2020, 11:22 am by srishtiasrn
hello..  i am also using ov7670 camera and the codes are working i mean it is successfully uploaded. As far as i have i have read about the working of the camera and arduino, i get to konw that due less memory of arduino uno only one single row pixels are stored at a time in the flash memory of arduino uno and  as we know that the camera outputs two bytes data for each pixel. so is it possible to read those bytes for a complete row in serial monitor? if possible, how can we do that? Also after uploading is over, if i open the serial monitor i get the following thing *RDY*???(a lots of question mrak) why is it so? and does it mean? can anybody please tell me soon??
vky021
i am also have same this problem
