gdsports:
The following is a simpler device that might work for your application. I have never used so I cannot answer any questions about it.USB Host Board – Keyboard Software – HobbyTronics
Note the pro mini must operate using 3.3V logic levels to work with the USB host mini board. These two boards together appoximate the capabilities of the Hobbytronics device.
The usb host mini has a SPI interface and the ESP32 has a SPI interface so there is no need for the pro mini or the hobbytronics device. But whatever is easiest for you.
In the USBHIDBootKbd example, the following functions will be called when a USB keyboard key is pressed. OnKeyDown is called for regular keys and OnControlKeysChanged is called for shift key(shift, control, alt, GUI/Windows). Put your code to handle the keys inside one of these functions.
Usb.Task() keeps checking the keyboard for key presses then calls one of the above functions when a key is pressed. There is no need for a Keyboard.read function.
It does not help to post multiple messages all over the board all on the same topic.
Thank you very much for all.
I was learning these things from a Portuguese tutorial
Two questions and an apologize
Question 1:
The device you posted needs to be uploaded a software but not via its USB but via boards like this ?
Question 2:
Then the keys are read by D32 from serial/I2C?
Apologize:
Excuse me for the comments on the posts but in all those posts different people were involved so I thought about asking to all of them, since the posts were very old.
