Topic: Having trouble with Pro Mini as arduino as programmer (Read 395 times) previous topic - next topic
appleshop
Hi guys!
I'm trying to upload some program on my pro mini using arduino as the programmer. Below's the connection.
Vcc -> 5V
Gnd -> Gnd
Rst  -> Rst
Tx0 -> Tx0
Rx1 -> Rx1
Here's the error im getting.
Arduino: 1.8.4 (Windows 7), Board: "Arduino Pro or Pro Mini, ATmega328P (5V, 16 MHz)"
Build options changed, rebuilding all
Sketch uses 928 bytes (3%) of program storage space. Maximum is 30720 bytes.
Global variables use 9 bytes (0%) of dynamic memory, leaving 2039 bytes for local variables. Maximum is 2048 bytes.
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0xe0
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0xe0
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0xe0
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0xe0
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0xe0
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0xe0
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0xe0
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0xe0
An error occurred while uploading the sketch
option enabled in File -> Preferences.
Is it okay if I used pin 1 for Rx then pin 0 for Tx?
BabyGeezer
Hi guys!
which one ?
the target board is Pro Mini, what is the programmer board ?
Vcc -> 5V
Gnd -> Gnd
Rst  -> Rst
Tx0 -> Tx0
Rx1 -> Rx1
you should use the pins 10-13 for ISP programming.
read this one;
https://www.arduino.cc/en/Tutorial/ArduinoISP
Attach your images to be viewed directly - THIS WAY;
https://forum.arduino.cc/index.php?topic=519037.0
