Topic: High speed encoder, data acquisition, save data 13kHz (Read 553 times) previous topic - next topic
maddumagewaruna
I have a quadrature encoder which generates 400 pulses per one rotation (1 x 100 ppr).
I'm trying to use this encoder to measure the angle of rotation of a motor.
The speed of the motor varies from 500 rpm to 2000 rpm.
At max speed of the motor, I need to capture 13,000 pulses per one second.
I need to count the number of pulses and save the number of pulses against a time stamp.
So basically, I need to save the number of pulses against time for every pulse.
which means I will have to save data at least at a rate of 13kHz. (13,000 information per one second)
What is the method I can use to store my data at such a rate.??
ard_newbie
#1
Mar 25, 2018, 01:10 pm Last Edit: Apr 25, 2018, 05:33 pm by ard_newbie
I bet for an X-Y problem.  Usually a quadrature decoder is used to provide an accurate input for a PID, recording the time for each and every edge is useless.
Is it a school assignment?
What is the final goal of your project?
There are several ways to record data, depending on the final goal:
- log data inside SRAM (96 Kbytes ) if recording don't last too much.
- SerialUSB.write() to a PC , then record on the PC.
- SDFAT Library.
- More exotic, record on an SD card via the HSMCI peripheral :
http://forum.arduino.cc/index.php?topic=188360.0
