Topic: Dividing by 1023 or 1024? The final verdict on analogRead (Read 13025 times) previous topic - next topic
TolpuddleSartre
GoForSmoke
If you can't answer points, imply everything comes down to a single issue.
With a 1.024V ref I can work the 10 bits of the ADC ladder value as factors of 1 mV, knowing instrument error from specs.
Please understand that doing so does not involve conversion to volts and treats the ADC value as a range.
If you fixate on hardware details you may lose signt of the what you're doing with them part. Or you're a EE.
1) http://gammon.com.au/blink  <-- tasking Arduino 1-2-3
2) http://gammon.com.au/serial <-- techniques howto
Your sketch can sense ongoing process events in time.
Your sketch can make events to control it over time.
Robin2
Do you mean?
Look back at the 0-5 example in Reply #21
At least work to the ADC value where possible, it's the conversion of ranges to values that forces errors.
I agree 100%. I am just pursuing this Thread for intellectual fun.
...R
Two or three hours spent thinking and reading documentation solves most programming problems.
GoForSmoke
The fun part is that with a 1.024V Vref, just going by 1mV x ADC the most you get is 1.023mV.
AVR has a built-in 1.1V Vref for 1.074mV steps x highest possible read 1023 = 1.099V.
If that 1.1V could be voltage divided to a 1.023Vref (perfect world), that would be conversion-friendly IF you're into converting.
Budvar10
ADC/1024 is correct, and ADC/1023 is wrong!
Let say we have just 1 bit ADC, 0 or 5V. Just two possible values. Should be /0 used?
And here is for n=5:
First *x/(n-1) math:
input voltage   ADC value   ADC*x/(n-1)   result   average error   output
4.00-4.99       4           *5/4          5.00     +0.50           5
3.00-3.99       3           *5/4          3.75     +0.25           3
2.00-2.99       2           *5/4          2.50      0.00           2
1.00-1.99       1           *5/4          1.25     -0.25           1
0.00-0.99       0           *5/4          0.00     -0.50           0
Note that for the 5 possible ADC values, the output scale now has 6 values (0-5)
and the value 4 can never occur! And although the average error might look to be
nicely distributed +/- the centre of scale, the actual output result proves to be
much uglier. For slowly increasing voltage, the ADC would read; 0, 1, 2, 3, 5!!!
The maximum error in real world use is 2V, because that very tiny change of
3.999V - 4.001V would cause an output change of 3V -> 5V or a change of 2V!
Correct scaling math *x/n:
input voltage   ADC value   ADC*x/n       result   average error   output
4.00-4.99       4           *5/5          4.00     -0.50           4
3.00-3.99       3           *5/5          3.00     -0.50           3
2.00-2.99       2           *5/5          2.00     -0.50           2
1.00-1.99       1           *5/5          1.00     -0.50           1
0.00-0.99       0           *5/5          0.00     -0.50           0        #
All output values are properly scaled and all are represented. The average error
is never greater than 0.5 (no more average error than the /(n-1) example),
the average error is always one fixed value (-0.5) making it very easy
to compensate. The maximum error at any time is 1V, this is half the max error of
the /(n-1) example, which can introduce extra error up to 1 in high value ADC
readings
Arduino clone with ATmega1284P   http://forum.arduino.cc/index.php?topic=277260.0
Robin2
Referring to Reply #34 ...
I think the assumption that 4.00 to 4.99 gives 4 and 3.00 to 3.99 gives 3 is incorrect. I would expect 4.5 to 4.99 to give 5 and 3.5 to 4.49 to give 4
...R
TolpuddleSartre
#36
Mar 29, 2018, 10:49 am Last Edit: Mar 29, 2018, 04:49 pm by TolpuddleSartre
Please, can someone put this thread out of its misery?
Oh, the humanity!
No, because 21 is 2, so by GoForSmoke's logic, we would divide by 1.
Robin2
lastchancename
...and this thread explains why binary logic wins!
We don't need no stinkin' analog!
Zero or One - none of this warm, fuzzy stuff. It just confuses things.
Can we kill this thread?  Although it has had interesting moments!
Experienced responders have a nose for laziness, (they were beginners once)... Sure, there are trolls, chest-beaters, and pretenders - but the help you'll get here is about as good as it gets - if you try to help youself!.
GolamMostafa
#39
Mar 29, 2018, 05:40 pm Last Edit: Mar 29, 2018, 05:42 pm by GolamMostafa
Maybe it is time to move it to Bar Sport ?
It's very interesting that the OP has not yet made any comment; but, you want move to the Bar Sport leaving him behind?
lastchancename
Bar Sport is Probably better than TUTORIALS.
Maybe Programming Questions?
Robin2
No. He must come with us.
...R
GoForSmoke
readings
Oh, the humanity!
These are rather poor strawmen.
TS, how do YOU convert a single bit into voltage with any more accuracy than what you think to ridicule?
Oh? What? You can't?
Bud, if you measure only 5 steps, the CONVERSION error is no longer 3 orders of magnitude below instrument error.
The error diminishes at n(n-1) rate. I argue on practicalities that do not scale freely. Please at least stay in the ballpark!
I gave clear reasons that you don't address at all and instead erect these pre-broken strawmen.
Coding Badly
#44
Mar 29, 2018, 07:51 pm Last Edit: Mar 29, 2018, 07:52 pm by Coding Badly
That is not how the AVR analog-to-digital converter works.  A one bit successive approximation converter with a reference of 5 volts makes just a single comparison: Is the voltage less than 2.5 volts?  If the answer is "yes" then the converted value is zero.  If the answer is "no" then the converted value is one.
