Topic: two Limit switches in 360 servo (Read 332 times) previous topic - next topic
cjgottonight
Hi Good morning.
I would like to ask about the limit switch?
I was working for 360 continuous servo with a two  limit switches and I want to stop it with  every position. because I was doing a final project.
I have to put my two limit switches in the 360 servo.
in the First station " initial position" there are two limit switches standby.
the first limit switch it will stop in every position or station because I want to stop it in 7 station.
and then when it hit to second limit switch it will go back to initial position.
I will show you my codes:
#include <Servo.h>
int x = 0;
int y = 0;
int limitIN =  7;
int limitOUT = 8;
int buttonstate = 0;
int buttonstate1 = 0;
Servo myservo;
  pinMode( limitIN, INPUT );
  pinMode( limitOUT , INPUT );
  myservo.attach(9);
  myservo.write (90);
  buttonstate = digitalRead (limitIN);
  if (buttonstate == 0) {
    while  (buttonstate == 0) {
      myservo.write (80);
    myservo.write (90);
    x = 1;
    y = 0;
  Serial.println ("done");
  buttonstate1 = digitalRead (limitOUT);
 // Serial.println (buttonstate);
  //delay (50);
  // Serial.println (limitOUT);
  //while (buttonstate1 == 0);
  // buttonstate = digitalRead (limitIN);
  //   myservo.write (85);
  //   myservo.write (90);
Grumpy_Mike
#1
Mar 26, 2018, 04:34 pm Last Edit: Mar 26, 2018, 04:35 pm by Grumpy_Mike
Is there a question here?
The vast majority of continuous servos do not move to a position. The only thing you can do is to make it run in one direction or the other. Is your servo different?
Quote
In what way would the requirement change if you were not doing a final project?
slipstick
Post a link to the specification of the particular servo you are using so we have a better idea of what you're describing.
Your code doesn't do anything at all with the limit switches so you need to at least make some attempt at doing whatever it is you want. Then tell us what it does and what you want it to do different.
How do you expect that only two limit switches will allow you to recognise 7 different positions?
Steve
