Topic: stepper drivers (Read 463 times) previous topic - next topic
sheepherder
I have a project going and need advice on stepper drivers, I am running the motor for long periods of time I'm getting skipping when my L298N gets hot. Can someone tell witch driver I need to use
Grumpy_Mike
Only if you tell us what stepping motor you have, what current it takes, what voltage you are driving it with and what driver you are using.
Robin2
These links may help
Stepper Motor Basics
Simple Stepper Code
If you need more information post a link to the datasheet for your stepper motor and tell us what stepper motor power supply (volts and amps) you are using.
...R
Two or three hours spent thinking and reading documentation solves most programming problems.
groundFungus
#3
Apr 02, 2018, 04:15 am Last Edit: Apr 02, 2018, 04:18 am by groundFungus
Please post a data sheet for the motor.   There is no way to make an intelligent recomendation with the information posted.
Stepper basics
Robin2
Don't double Post.
You have caused @groundFungus to waste time giving you an answer that you already had in your other Thread
...R
