Topic: Measuring joules/watts? (Read 3266 times) previous topic - next topic
cloister
I would like to do a little project with a solar panel, something to measure the actual watts coming out of the thing, and an Arduino to integrate the panel's output over time.
However, I haven't any idea of how I would build a circuit to measure the actual amount of power the panel is producing.  Is there an off-the-shelf component that will measure that for me?  Or measure some  related value(s) through which I can calculate the watts?
Any pointers to circuit diagrams, wikipedia pages, or anything to help me get going would be greatly appreciated.
weirdo557
a voltage divider to scale the voltage so it can be measured, and a current sensor to measure the current. you could use a shunt resistor and measure the voltage drop, or you can use a hall effect sensor to measure it.
cloister
Cool.  So, measure the volts and amps coming out of the panel, because W = V*A.  Makes sense.
Being an electronics NOOB, can anybody recommend some Arduino-friendly parts / circuit diagrams for the ammeter portion?
weirdo557
do you know the power your panels are rated at?
Artem_F
you've got the right answer in #2.
Here's the circuit for current measurement:
panel output ----load---1-RRRRR-ground
RRRRR = 1Ohm resistor
1 - point to be connected to the analog input of your Arduino.
Measure the voltage at this point, the current will be the voltage / 1ohm
weirdo557
1 ohm is kinda high for any significant current though. a smaller shunt and an op-amp would work nicely, or a hall effect.
cloister
Sweet! I should have known SparkFun would have something. That looks just about perfect.  Thanks so much!
MarkT
Although its rather expensive - look for other current sensors if you dont require the high-side monitoring feature.
janeik
P= (U*U)/R
P=(I*I)*R
A static known resistance and measure of U or I, willl give a simple equation to calculate P. No need to measure both.
regards
MarkT
But the requirement is to measure the power delivered into the actual load, not a resistor!
weirdo557
by measuring the voltage drop across a resistor you calculate the current flowing through the circuit, which is equal to the current going into the battery.
