Topic: Crazy buttons. (Read 682 times) previous topic - next topic
Garriden
I am working with an arduino DUE with industrial servo motors.
I need to attach 6 buttons, the problem is, sometimes these buttons activates himself alone (blink). Why it could be? The fact that it's working in a hard enviorment?
Also, to activate the buttons, I need a pull-down, so I implemented via software a !pullup.
pinMode(B1, INPUT_PULLUP);
Joystick.state.buttons.b00 = !digitalRead(B1);
Is it right? or is it silly? Should be better craft an phisical pull-down with a correct resistor? I don't know how INPUT_PULLUP works inside a DUE.
I would appreciate any help, thanks.
ard_newbie
#1
Apr 03, 2018, 01:45 pm Last Edit: May 12, 2018, 06:16 pm by ard_newbie
If your switch is activated randomly, hook a pull-down resistor to avoid EMI (VCC is 3.3V for a DUE):
http://www.resistorguide.com/pull-up-resistor_pull-down-resistor/
Next is the debouncing issue:
https://forum.arduino.cc/index.php?topic=138887.0
Garriden
Ok, I implemented a physical pull-down and now it works perfect.
Thanks.
