Topic: Help on how to read rc receiver in arduino nano (Read 2195 times) previous topic - next topic
rossi86m
Hello!!!!
I have just bought a rc receiver to continuo working on my bicopter project.
I was checking google to see how to read the rc receiver and i saw that there different ways to do it.
Can you share some code to read the rc receiver channels on the arduino nano???
Thanks in advance!!!
Marco
vinceherman
#1
Apr 06, 2018, 07:15 pm Last Edit: Apr 06, 2018, 07:17 pm by vinceherman
These are the links I keep on hand for bringing myself back up to speed.
http://playground.arduino.cc/Code/ReadReceiver
http://rcarduino.blogspot.com/2012/01/how-to-read-rc-receiver-with.html
Edit: Uh, pics.  Cause cool projects require pics! :)
Another edit: What receiver did you get?  If it supports PCCM (or any of the single pin protocols) you only need one arduino pin to read it.
rossi86m
As far as i could check the code the problem is that it uses timer uno. The servo library that i use to move the servos also use it so it will cause conflicts.
Am I wrong?
any idea?
slipstick
What code? And you haven't answered the question about what receiver.
There is a simplified alternative servo library called ServoTimer2.
Steve
rossi86m
Sorry the rc controles is the flysky fs-i6
vinceherman
Read through the second link.  He mentions that he does not sue the timer.  I admit that I have not run into conflict, but I ended up going a different way.  CPPM (I typoed above) lets me use just one pin/interrupt.
vinceherman
Oh, that receiver has iBus.
This library looks like it was written to read that protocol.
rossi86m
What do you mean with "I ended up going a different way" what did you do
Btw some pics
rossi86m
How should i use this???
Sorry for the stupid question but this is brand new for me
vinceherman
I have not used that library (because I do not have your receiver)
But it has an examples section with code you can try.
Are you comfortable installing a library?  I usually fumble around copying it to different locations until my code compiles.
You design looks cool.  I would worry that the motors will twist off of the servos.  I think you need a bearing on the opposite side from the servo to relieve the load of the motor lift and torque.
rossi86m
Thanks!
What i need to figure out is how to connect the receiver to the arduino. If you have an idea on how to wire it up i will appreciate it
I am new to the rc controller. I have been playing with this bicopter project for a year. I made an arduino app to control it but it is almos imposible to control it.
Thanks for the advice about the motor. i tested it and it seems to work ok
Thanks again,
Marco
rossi86m
I now understand how ibus works
I should connect it to serial (rx) pin
is that right?
vinceherman
#12
Apr 06, 2018, 09:33 pm Last Edit: Apr 06, 2018, 09:34 pm by vinceherman
Here is an image I hacked up to try to demonstrate.
rossi86m
Yes i understand
Bad news my controller doesnt have ibus
the controler is the Fs-ia6
Any suggestion?
vinceherman
Quote
but it is almost impossible to control it.
I see a nano.  Is that a gyro behind it?
