I made bitmap style arrays for the characters and was able to display each character in sequence after some bug hunting. I think I may have stumbled on the reason why the original author could not store both upper case and lowercase letters in his array; I tried to put all 93 characters into one array and got garbage when I tried to display each character in sequence. I did the math, each array element is 9 bytes long and there are 93 (94 if you count a space, ASCII 32) elements. 94 x 9 = 846, just under 1KB.
I split the array up into letters, numbers and symbols, and it worked fine. Go figure.
Here are the array declarations if you care to use them. I took the characters from the character map of a CrystalFontz 634, 4x20 character LCD screen. Each character is 5 pixels wide by 7 pixels tall.
My next task is to string the characters together somehow and then use the bitmap display function to scroll text across the LoL shield.
Putting all the characters together in one array causes garbage to
appear on the screen at random when attempting to display each
//uint16_t letters[] [9] = {
uint16_t BitMap[][9] = {
{0,14,17,17,17,31,17,17,0}, //65, A
{0,15,17,17,15,17,17,15,0}, //66, B
{0,14,17,1,1,1,17,14,0}, //67, C
{0,7,9,17,17,17,9,7,0}, //68, D
{0,31,1,1,15,1,1,31,0}, //69, E
{0,31,1,1,15,1,1,1,0}, //70, F
{0,14,17,1,29,17,17,30,0}, //71, G
{0,17,17,17,31,17,17,17,0}, //72, H
{0,14,4,4,4,4,4,14,0}, //73, I
{0,28,8,8,8,8,9,6,0}, //74, J
{0,17,9,5,3,5,9,17,0}, //75, K
{0,1,1,1,1,1,1,31,0}, //76, L
{0,17,27,21,17,17,17,17,0}, //77, M
{0,17,17,19,21,25,17,17,0}, //78, N
{0,14,17,17,17,17,17,14,0}, //79, O
{0,15,17,17,15,1,1,1,0}, //80, P
{0,14,17,17,17,21,9,22,0}, //81, Q
{0,15,17,17,15,5,9,17,0}, //82, R
{0,30,1,1,14,16,16,15,0}, //83, S
{0,31,4,4,4,4,4,4,0}, //84, T
{0,17,17,17,17,17,17,14,0}, //85, U
{0,17,17,17,17,17,10,4,0}, //86, V
{0,17,17,17,21,21,21,10,0}, //87, W
{0,17,17,10,4,10,17,17,0}, //88, X
{0,17,17,17,10,4,4,4,0}, //89, Y
{0,31,16,8,14,2,1,31,0}, //90, Z
{0,0,0,14,16,30,17,30,0}, //97, a
{0,1,1,13,19,17,17,15,0}, //98, b
{0,0,0,14,1,1,17,14,0}, //99, c
{0,16,16,22,25,17,17,30,0}, //100, d
{0,0,0,14,17,31,1,14,0}, //101, e
{0,12,18,2,7,2,2,2,0}, //102, f
{0,0,30,17,17,30,16,14,0}, //103, g
{0,1,1,13,19,17,17,17,0}, //104, h
{0,4,0,6,4,4,4,14,0}, //105, i
{0,8,0,12,8,8,9,6,0}, //106, j
{0,1,1,9,5,3,5,9,0}, //107, k
{0,6,4,4,4,4,4,14,0}, //108, l
{0,0,0,10,21,21,21,21,0}, //109, m
{0,0,0,13,19,17,17,17,0}, //110, n
{0,0,0,14,17,17,17,14,0}, //111, o
{0,0,0,15,17,15,1,1,0}, //112, p
{0,0,0,14,9,14,8,24,0}, //113, q
{0,0,0,13,19,1,1,1,0}, //114, r
{0,0,0,14,1,14,16,15,0}, //115, s
{0,2,2,7,2,2,18,12,0}, //116, t
{0,0,0,17,17,17,25,22,0}, //117, u
{0,0,0,17,17,17,10,4,0}, //118, v
{0,0,0,17,17,21,21,10,0}, //119, w
{0,0,0,17,10,4,10,17,0}, //120, x
{0,0,0,17,17,30,16,14,0}, //121, y
{0,0,0,31,8,4,2,31,0}, //122, z
{18000}
uint16_t numbers [][9] = {
//uint16_t BitMap[][9] = {
{0,14,17,25,21,19,17,14,0}, //48, 0
{0,4,6,4,4,4,4,14,0}, //49, 1
{0,14,17,16,8,4,2,31,0}, //50, 2
{0,31,8,4,8,16,17,14,0}, //51, 3
{0,8,12,10,9,31,8,8,0}, //52, 4
{0,31,1,15,16,16,17,14,0}, //53, 5
{0,12,2,1,15,17,17,14,0}, //54, 6
{0,31,16,8,4,2,2,2,0}, //55, 7
{0,14,17,17,14,17,17,14,0}, //56, 8
{0,14,17,17,30,16,8,6,0}, //57, 9
{18000}
//uint16_t symbols [][9] = {
{0,4,4,4,4,4,0,4,0}, //33, !
{0,10,10,10,0,0,0,0,0}, //34, "
{0,10,10,31,10,31,10,10,0}, //35, #
{0,4,30,5,14,20,15,4,0}, //36, $
{0,3,19,8,4,2,25,24,0}, //37, %
{0,6,9,5,2,21,9,22,0}, //38, &
{0,6,4,2,0,0,0,0,0}, //39, '
{0,8,4,2,2,2,4,8,0}, //40, (
{0,2,4,8,8,8,4,2,0}, //41, )
{0,0,4,21,14,21,4,0,0}, //42, *
{0,4,4,31,4,4,0,0,0}, //43, +
{0,0,0,0,6,4,2,0,0}, //44, ,
{0,0,0,0,31,0,0,0,0}, //45, -
{0,0,0,0,0,0,6,6,0}, //46, .
{0,0,16,8,4,2,1,0,0}, //47, /
{0,6,6,0,6,6,0,0,0}, //58, :
{0,6,6,0,6,4,2,0,0}, //59, ;
{0,8,4,2,1,2,4,8,0}, //60, <
{0,0,31,0,31,0,0,0,0}, //61, =
{0,2,4,8,16,8,4,2,0}, //62, >
{0,14,17,16,8,4,0,4,0}, //63, ?
{0,14,17,25,21,29,1,14,0}, //64, @
{0,14,2,2,2,2,2,14,0}, //91, [
{0,0,1,2,4,8,16,0,0}, //92, backslash,
//putting in an actual backslash character in this comment prevents
//the next character from showing
{0,14,8,8,8,8,8,14,0}, //93, ]
{0,4,10,17,0,0,0,0,0}, //94, ^
{0,0,0,0,0,0,0,31,0}, //95, _
{0,2,4,8,8,0,0,0,0}, //96, `
{0,8,4,4,2,4,4,8,0}, //123, {
{0,4,4,4,0,4,4,4,0}, //124, |
{0,2,4,4,8,4,4,2,0}, //125, }
{0,0,2,21,8,0,0,0,0}, //126, ~
{18000}
