Topic: Getting Errors even though I downloaded sample code...NEED HELP ASAP PLZ! (Read 1 time) previous topic - next topic
ArduinoNoobNeedHelp
so i am using a gsm shield sim900 with a tmobile sim card and an arduino uno...I used the SMS Sender code from this youtube link: https://www.youtube.com/watch?v=n-RkWRUw62g
However I get these errors liste below. IF YOU COULD PLEASE HELP ME ASAP I WOULD GREATLY APPRECIATE IT!
C:\Users\Saad\Desktop\EDD\SMSSender\SMSSender.ino: In function 'void setup()':
C:\Users\Saad\Desktop\EDD\SMSSender\SMSSender.ino:49:54: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
         if (sms.SendSMS("+19569758590", "Arduino SMS"))
C:\Users\Saad\Desktop\EDD\SMSSender\SMSSender.ino: In function 'void loop()':
SMSSender:69: error: no matching function for call to 'SMSGSM::GetSMS(char&, char [20], char [100], int)'
             sms.GetSMS(sms_position, phone_number, sms_text, 100);
C:\Users\Saad\Desktop\EDD\SMSSender\SMSSender.ino:69:65: note: candidate is:
In file included from C:\Users\Saad\Desktop\EDD\SMSSender\SMSSender.ino:8:0:
C:\Users\Saad\Documents\Arduino\libraries\GSM-GPRS-GPS-Shield-GSMSHIELD/sms.h:12:11: note: char SMSGSM::GetSMS(byte, char*, byte, char*, byte)
      char GetSMS(byte position, char *phone_number,byte max_phone_len, char *SMS_text, byte max_SMS_len);
C:\Users\Saad\Documents\Arduino\libraries\GSM-GPRS-GPS-Shield-GSMSHIELD/sms.h:12:11: note:   candidate expects 5 arguments, 4 provided
exit status 1
TolpuddleSartre
I'd love to help you, but you didn't post your code.
Quote
Seems pretty clear to me.
ArduinoNoobNeedHelp
here is my code:
#include <call.h>
#include <gps.h>
#include <GSM.h>
#include <HWSerial.h>
#include <inetGSM.h>
#include <LOG.h>
#include <SIM900.h>
#include <sms.h>
#include <Streaming.h>
#include <WideTextFinder.h>
  //        Arduino GSM SHIELD SMS         //
 //              Tutorial by                          //
//           http://www.educ8s.tv             //
#include "SIM900.h"
#include <SoftwareSerial.h>
#include "sms.h"
SMSGSM sms;
int numdata;
boolean started=false;
char smsbuffer[160];
char n[20];
char sms_position;
char phone_number[20];
char sms_text[100];
int i;
    if (gsm.begin(9600))
        Serial.println("\nstatus=READY");
        started=true;
        Serial.println("\nstatus=IDLE");
    if(started)
          Serial.println("\nSMS sent OK.");
          Serial.println("\nError sending SMS.");
    if(started)
        sms_position=sms.IsSMSPresent(SMS_UNREAD);
        if (sms_position)
            Serial.print("SMS postion:");
            Serial.println(sms_position,DEC);
            Serial.println(phone_number);
            Serial.println(sms_text);
        delay(2000);
TolpuddleSartre
If you look at the example code you based your sketch on,  you need to compare the call to the GetSMS function in the example with your call to the same function.
The compiler has already given you plenty of clues.
ArduinoNoobNeedHelp
so would i add call into this code: sms.GetSMS(sms_position, phone_number, sms_text, 100);
i am sorry but i am a complete beginner at this  :'(
TolpuddleSartre
That's just four arguments again (count them), and the compiler doesn't like it.
ArduinoNoobNeedHelp
Ok so my goal here is to try to text and call a number by the way lol.
So I updated my code:
#include <call.h>
#include <gps.h>
#include <GSM.h>
#include <LOG.h>
#include <SIM900.h>
#include <sms.h>
 //              Tutorial by                 //
#include "SIM900.h"
#include "sms.h"
#include <call.h>
SMSGSM sms;
int numdata;
char n[20];
char sms_position;
char sms_text[100];
int i;
        started=true;
    if(started)
    if(started)
        if (sms_position)
            sms.GetSMS(call, sms_position, phone_number, sms_text, 100);
        delay(2000);
and got a different error this time; if you could adress each problem i would greatly appreciate it...i am very sorry for this trouble. Following shows error messages:
C:\Users\Saad\Desktop\EDD\SMSSender\SMSSender.ino:50:54: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
SMSSender:70: error: 'call' was not declared in this scope
exit status 1
TolpuddleSartre
You have one error - the others are warning.
The code has a byte variable called "call", but you haven't defined it.
Look again at the example and see how "call" is defined and used.
It may even be a function returning byte.
ArduinoNoobNeedHelp
ah ok
so in the example, i dont think call was used but I am trying to do it by myself
what if I just wanted to send SMS for the first part...like i would like to get that part configured first before going to call...what do i need to do for the sneding messages to work
TolpuddleSartre
I have absolutely no idea - I don't have your hardware, so I don't have the library either
ArduinoNoobNeedHelp
can i send the code for just the SMS and you can let me know what I am doing wrong?
so this is code for just sms:
 //              Tutorial by                 //
#include "SIM900.h"
#include "sms.h"
SMSGSM sms;
int numdata;
char n[20];
char sms_position;
char sms_text[100];
int i;
        started=true;
    if(started)
    if(started)
        if (sms_position)
        delay(2000);
and i get this error:
C:\Users\Saad\Desktop\EDD\SMSSender\SMSSender.ino:39:54: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
SMSSender:59: error: no matching function for call to 'SMSGSM::GetSMS(char&, char [20], char [100], int)'
C:\Users\Saad\Desktop\EDD\SMSSender\SMSSender.ino:59:65: note: candidate is:
In file included from C:\Users\Saad\Desktop\EDD\SMSSender\SMSSender.ino:12:0:
Multiple libraries were found for "SIM900.h"
 Used: C:\Users\Saad\Documents\Arduino\libraries\SIM900
 Not used: C:\Users\Saad\Documents\Arduino\libraries\GSM-GPRS-GPS-Shield-GSMSHIELD
exit status 1
i copied exactly from the video example i dont know why i am getting an error?
TolpuddleSartre
We seem to be back where we started.
The function GetSMS expects/requires five arguments, and you're giving it four.
ArduinoNoobNeedHelp
how can i get it to only require four arguments or what is the fifth argument that i need to add?
TolpuddleSartre
Please, just post the example code you based this on, but please use code tags this time.
ArduinoNoobNeedHelp
this is the link for the example code i used: http://educ8s.tv/arduino-gsm-shield/
the example code is in there unless you want me to post it here though i do not know how to used code tags
<code>
#include "SIM900.h"
#include "sms.h"
SMSGSM sms;
int numdata;
char n[20];
char sms_position;
char sms_text[100];
int i;
        started=true;
    if(started)
        if (sms.SendSMS("+300000000000", "Arduino SMS"))
    if(started)
        if (sms_position)
        delay(2000);
<code>
