Topic: LiquidCrystal_I2C Arduino Due (Read 3664 times) previous topic - next topic
taronov
Hello, I have the following problem.
I can not run an I2C LCD through an arduino duo, which gives me the following error. I'm glad if you help me.
WARNING: library LiquidCrystal_I2C claims to run on (avr) architecture(s) and may be incompatible with your current board which runs on (sam) architecture(s).
Sketch uses 25252 bytes (4%) of program storage space. Maximum is 524288 bytes.
Atmel SMART device 0x285e0a60 found
Erase flash
done in 0.033 seconds
ard_newbie
#1
Apr 09, 2018, 02:05 pm Last Edit: Apr 09, 2018, 02:16 pm by ard_newbie
I guess you included an LCD Library for an AVR ?
Examples of LCD via I2C over a DUE:
http://www.armlearning.com/code/arduino-due/arduino-due-i2c-lcd-example.php
http://theelectromania.blogspot.fr/2016/01/clock-and-calendar-using-arduino-due.html
ilguargua
I have the same warning using LiquidCrystal_I2C on Due, but the display is working anyway. FYI I use 5V supply for display and level converter for I2C.
Ciao, Ale.
