Topic: EEprom storing serial input (Read 1 time) previous topic - next topic
Giga_question
Apr 09, 2018, 07:09 pm Last Edit: Apr 10, 2018, 11:03 am by Giga_question
I have a question. I am making a game with another board by BBC, and using Arduino as storage. I want to know how can I Do this. It is transferring info via TX and RX.
THX
PaulS
Quote
What is? Transferring data to what?
Serial data consists of bytes. EEPROM stores bytes. What a perfect fit. What IS the problem?
Giga_question
The arduino and BBC micro:bit
ieee488
transferring via RX and TX?
really?
According to it's website, it has Bluetooth BLE and a "radio"
The radio is for communication to another BBC micro:bit.
It does have a USB for downloading programs into the BBC micro:bit and for powering it.
I am not seeing where RX / TX is possible.
Giga_question
#4
Apr 20, 2018, 08:36 am Last Edit: Apr 20, 2018, 08:41 am by Giga_question
You may not see it, but you can set it up.serial.redirect(SerialPin.P0, SerialPin.P1, 9600)
ieee488
#5
Apr 20, 2018, 03:50 pm Last Edit: Apr 20, 2018, 03:51 pm by ieee488
And where is this information?
Anyway, serial into Arduino then Arduino write to EEPROM
or Arduino read from EEPROM then serial from Arduino to BBC micro:bit
You need to write the code on both ends.
Giga_question
Ok thanks for being patient with me.
You've answered quite well THX
arceoedrian
HI , I'm new in using eeprom storage i want to store last command in may arduino during power interaction  , GMS to arduino  Im sending character 'a' in GSM , how can i save in the eeprom of arduino, any one can help me. Thanks
arceoedrian
my code is working in arduino  using GSM and Bluetooth my problem is during power interaction , i need to store the last command.
Giga_question
I don't know much about coding in with bluetooth, but if there is such thing as a incoming bluetooth string then I would set a variable in voidloop() to bluetooth strings then put
EEPROM.write(address, bluetoothstring)
Or something like that
PaulS
Quote
Permission granted. If you need help, POST YOUR CODE.
arceoedrian
I send character both  Bluetooth and GSM  , but i don't know to save in eeprom in arduino
arceoedrian
may be i will post my code , I hope you can help me . thanks
arceoedrian
int R1pin=11;
int R2pin=9;
char inByte;
char incomingByte ;
int R1State=0;
int R2State=0;
 Serial2.begin(9600);   // Setting the baud rate of H-05 Module
 Serial1.begin(9600);   // Setting the baud rate of GSM Module
 Serial.begin(9600);    // Setting the baud rate of Serial Monitor (Arduino)
 pinMode(11,OUTPUT);
 pinMode(9,OUTPUT);
 pinMode(2,OUTPUT);
 Serial.println (" Ready");
 //delay( 200);
 digitalWrite (11, HIGH);
 digitalWrite (9, HIGH);
 START:
 if (Serial.available())
  switch(Serial.read())
   case 's':
     SendMessage();
     Serial.println( "TEST");
   case 'r':
    RecieveMessage();
     Serial.println( "RUN");
if (Serial1.available())
inByte= Serial1.read();
Serial.write(inByte);
//Serial.write(Serial1.read());
switch (inByte)
 case 'a':
  SendMessage();
 digitalWrite (11, LOW);
  delay(200);
  goto START;
 case 'b':
 digitalWrite (9, LOW);
  SendMessage1();
  delay(200);
  goto START;
void SendMessage()
 Serial1.println("AT+CMGF=1");    //Sets the GSM Module in Text Mode
 delay(500);  // Delay of 1000 milli seconds or 1 second
 Serial1.println("AT+CMGS=\"+639174220907\"\r\n"); // Replace x with mobile
 Serial1.println("APPLIANCES 1 ON:)");// The SMS text you want to send
 delay(100);
 Serial1.println((char)26);// ASCII code of CTRL+Z
void SendMessage1()
 Serial1.println("AT+CMGS=\"+639174220907\"\r"); // Replace x with mobile number
 Serial1.println("APPLIANCES 2 ON:)");// The SMS text you want to send
 delay(100);
arceoedrian
Hi, i posted my code both Bluetooth and GSM  please help on how to save the character in  in eeprom in arduino, i hope you can help me in my problem .. Thanks
