Topic: Capacitors (Read 545 times) previous topic - next topic
tinman13kup
What is it with nF that engineers don't like? I purchased some various smd capacitors from digikey and they really like pF, going up to 10000pF, then switch to .1uF.
I had to think for a second with a microchip I'm playing with, as they have a .1uF capacitor on a VDDIO pin, then call for a 100nF on a VREG pin. :smiley-confuse:
What am I missing?
Tom
It's not a hobby if you're not having fun doing it. Step back and breathe
MorganS
Because capacitors are so tiny, there is almost no space at all for marking the value. With through-hole capacitors and hand assembly, you must have the value written on the cap.
So the 2-digits-and-number-of-zeroes system works well on pF and nF capacitors. There's no space to write the p or the n, so the range is continuous, in pF only.
Once you get to uF sized capacitors, there is usually enough space to write the units and more details.
Now that everything is SMD (Yay!) this is less important but the tradition remains.
"The problem is in the code you didn't post."
tinman13kup
Ok, I'll go with that. There just isn't any way they are putting any numbers on these smd's, nor could you read them if they did. Still, I'm a bit befuddled why they put ".1uF" right next to a "100nF" on this datasheet. Personally, if one will get messed up it's going to be the "."1uF.
Tom
Grumpy_Mike
The use of nF as 10 -9 is comparatively recent, before 30 or 40 years ago it was not used.
This is mainly because capacitors were either in the pF range for RF applications or the uF range for timing.
polymorph
Before that, I remember listening to old timers and reading books that didn't say uF, they said MMF. Yes, all in caps, even. The old timers called them "micky-mikes".
Steve Greenfield AE7HD
Drawing Schematics: tinyurl.com/23mo9pf - tinyurl.com/o97ysyx - https://tinyurl.com/Technote8
Multitasking: forum.arduino.cc/index.php?topic=223286.0
gammon.com.au/blink - gammon.com.au/serial - gammon.com.au/interrupts
BabyGeezer
Attach your images to be viewed directly - THIS WAY;
https://forum.arduino.cc/index.php?topic=519037.0
MarkT
What am I missing?
In the old days there was no nano, pico, atto, femto, giga, tera, peta, exa.
There was only milli, micro, kilo, mega.
Capacitors were thus described using micros and micro-micros.  µF, µµF
The manufacturers lagged behind everyone else I think.  What's more they seemed
to have an aversion to millifarads (note there was never any aversion to milliohms).  pF replaced
µµF but for some reason nF wasn't popular, perhaps because there was no pre-existing prefix.
[ I DO NOT respond to personal messages, I WILL delete them unread, use the forum please ]
tinman13kup
I do recall some controversy of using "m" as a prefix instead of "milli". It was said there were too many issues with m/M and sloppy writing. The whole problem would rear it's head dealing with resistance and troubleshooting circuits and not so much the repair of the same circuit.
Quote
[\quote]
I would say there was no NEED for any of those values at that time.
Tom
